Modding MDVA Lite now available
Discussion in 'Modding' started by mashie, 5 Jul 2006.
  1. mashie
    mashie The one and only
    15 Mar 2002
    Now available, the MDVA Lite, a barebone enthusiast kit that contain the full MDVA PCB and cable for those of you that want to make your own enclosure.
    Link for more details including the new prices.
    Oh, if you wonder why you haven't seen a review here at Bit-Tech, blame Macroman for sitting on a unit for the past year ;)
  2. gideon
    gideon What's a Dremel?
    27 Feb 2006
    $20 is very affordable :D
  3. mashie
    15 Mar 2002
    Well it is less than half the manufacturing cost so almost a bargain. ;)
  4. offroadracer789
    offroadracer789 What's a Dremel?
    9 Dec 2004
    ooooh, i got one. Not having the enclosure gave me an excuse to get one. Are you ever going to release one without any LEDs so that we can put any color we want in it?
    I dont mind soldering smt leds, but i have absolutely no abilities whatsoever when it comes to desoldering them.
    edit: what screw size works best for the mounting holes?
  5. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    112 is a hell of alot of LED's to replace though...
  6. Kumo
    Kumo What's a Dremel?
    18 Oct 2004
    112 SMD leds!!!
    I got mine some months ago. And now i'm waiting the Lite Units arrive.
  7. mashie
    15 Mar 2002
    It will be posted tomorrow. There won't be any blank PCB versions, sorry. As for the mounting holes, they are 1/8" but you can easily drill them a lot bigger if needed, no traces are near.
  8. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
    Ever since you made one for anemone I've been wondering about ways to convert different system stats (like fan speed and temperatures) into sound so that you can display them on this and other visualizers. Like for example building a circuit to convert a thermistor or FAN RPM input into a sound spectrum range so that the visualizer could double as a temperature display by changing the audio source.
    Regardless this is a great deal and I applaud you for making them available and affordable.
  9. mashie
    15 Mar 2002
    Cool, that is an usage I haven't even considered, shouldn't be too difficult to do really.
  10. Captain Slug
    25 Nov 2001
    Do you have a mechanical drawing of the mounting holes and button placements?
  11. Kumo
    18 Oct 2004
    In his forum, though. Under the MDVA section.
  12. Captain Slug
    25 Nov 2001
    Ah, there we go. This is perfect.
    I might look into making a circuit board to convert fan RPMs and thermistors into spectral sound in a month or so. For now I'll just get the aluminum mount made to put it in my new machine.
  13. Firehed
    15 Feb 2004
    By the looks of the traces there, it only uses one voltage line (5v? I never remember my molexes...) - is that correct? If so, any idea on power draw? <500mA @ 5v would be awesome, though that's a whole lotta lights. I just got a fun little idea and I want to make sure it'd work electrically first. Though at that price, I really can't go wrong.
  14. CrazyModder
    CrazyModder What's a Dremel?
    13 Jun 2006
    Any plans in the future for a diferent color leds, like green or blue.
  15. Captain Slug
    25 Nov 2001
    Trying to power it from USB are we, hmmm?
  16. Firehed
    15 Feb 2004
    When someone does it first, they stole the idea from me.
    Yes, external USB-powered display to hook up to and sit under my iPod dock or something.
    LSDiodes' red SMDs apparently pull up to 35ma, but somehow I doubt this setup would require almost 4 amps - even 20 watts worth of LEDs would get fairly warm in such a small area. I'd rather find out from the man himself than toast a port, seeing as I can't really be bothered to wire up an ammeter to a molex for the testing.
    I do have a 2.6a power brick for a 4-port hub that I can use passively, I'd just rather not waste the outlet when I've got some insane number of available USB ports (and I don't want the multiple wires from doing it in parallel)
  17. Captain Slug
    25 Nov 2001
    I'll take a power draw reading when mine arrives and let you know what I get.
    You could always make a single USB power cable with two plug-in ends (in parallel) so that you can draw 1 amp instead of 500ma.
  18. Kumo
    18 Oct 2004
    No more MDVA releases planed, so get your unit now or never ;)
  19. CrazyModder
    13 Jun 2006
    OK! TK!
  20. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    Ordered! I already have ideas for a case too. I've wanted one of theses every since I saw that radio mod so many years ago.
