me axia!
Discussion in 'General' started by Koolvin, 9 Apr 2001.
  1. Koolvin
    Koolvin The Modfather
    12 Mar 2001
    ON a KT7-R gonna run stability tests.... stay tuned!
  2. Koolvin
    12 Mar 2001
    nah not stable at that- well runs windows etc but 3dmark goes tits up,
    1463 is fine passes 3dmark but gets too hot on prime95.. erm gonna try lowering voltage.
  3. Koolvin
    12 Mar 2001
    Stable at last...
    /me needs a better cooling system! damm thermoengines are a pain to get off ! so I am using a fop32-1
    These results are good because the normal Kt7-R get flakey after 112 FSB!!!
  4. moose
    moose New Member
    12 Mar 2001
    one (long) word!
    sweeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeet :D
  5. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    thats quite warm :) ... spose its only a fop32 though ..... wonder how well the CORe would do on that baby
  6. Jamie
    12 Mar 2001
    this is my new baby .... runs at 36 degrees while using seti :) very nice
  7. Ataraxia
    Ataraxia <b>OOH BABY!!!</b>
    12 Mar 2001
    WHEN THEY SAY PENCILLING THE L2 BRIDGES THEY MEAN SHORT THE CONTACTS, NOT STICK ON A STICKER WITH THE SPEED YOU WANT!!
    LOL etc :)
  8. Jamie
    12 Mar 2001
    lol ...... i knew something wasn't quite right with my bridges ... oh well here are the results of o/cing my cpu
    ^^^^^^^^ seti was running ^^^^^^^^
    RAM is @ 144mhz
  9. JADS
    JADS Et arma et verba vulnerant
    27 Mar 2001
    Hmm well this thing is at a nose bleeding 66MHz and my one upstairs runs at the truly screaming speed of 400MHz. Pah to your GHz machines is what I say, ;þ!
    I will have my revenge on all of you next year... Mwaaahhh haaaaa haaaaaaaaaaaaa mwwwwwwaaaaaaa....
    <-- Men in white coats take come to take me away for the second time after I bit one of them the first time
    James
  10. Delta
    Delta New Member
    23 Mar 2001
    you meant to say the L1's did you not, sir?
  11. Koolvin
    12 Mar 2001
    some other bridges usefull for setting voltages etc...
  12. Ataraxia
    12 Mar 2001
    L1, L2... who cares! lol i'm an intel sucka!
  13. RTT
    RTT #parp
    12 Mar 2001
    pah, this 486 licks all ur butts ;)
  14. herbs
    herbs Nobody but us chickens
    7 May 2001
    That is weak compared to my commadore 128k with an external floppy drive, it boots up faster than any mac or pc ;)
  15. Evilbob
    Evilbob New Member
    28 Apr 2001
    hmm im having probs with my board KT7 and my cpu, they don like bein overclocked , i have a 900 which shud run @ at least 1GHz but it dont all the time , i think its having mood swings!
  16. herbs
    7 May 2001
    Probably telling you what you have already done but try upping the voltage, use a good heatsink & fan (hsf), dont apply too much or little heat compound (remove that crappy thermal stuff at the bottom of the heatsink). Try a different bios, make sure the hsf on the chipset is clean and doesn't have a load of dust on it (even better replace it with a blorb or intel fpga hsf).
    Try the old pencil trick on the cpu, use less demanding memory settings. Now if any of the above don't do it then try http://www.viahardware.com/faq/kt7/kt7faq.htm
    PS I'm running my 800 @ 990 on kt7 without any probs.
