Other Meaco Fans
Discussion in 'General' started by Mr_Mistoffelees, 8 Aug 2026.
  1. Mr_Mistoffelees
    26 Aug 2014
  2. Mr_Mistoffelees
    26 Aug 2014
    Well, that didn't last very long...
  3. Arboreal
    21 Jan 2011
    Not surprised, it's still warm and more heat to come supposedly :eek:
  4. Ice Tea
    Ice Tea Multimodder
    26 Jul 2009
    After owning Meaco fans none of us in the family would go back to Dyson as they just make too much of a whining noise for the air that they move.
    Big Elf, Bloody_Pete, adidan and 2 others like this.
  5. Byron C
    Byron C AKA “Sticky Equilibrium” on weekends
    12 Apr 2002
    With a few exceptions, Meaco seems to have become a forum favourite.
    They lost a few points for me when I saw that the 8” Sefte fan uses a proprietary battery and a 12v DC barrel jack. Admittedly it’s way less powerful, but using easily-accessible 18650 cells and Type-C charging in the mini 260C fan earned them a lot of brownie points. The Sefte battery pack is almost certainly just a couple of 18650s in a plastic shell, and a cheap 35W USB-C PD charger has more than enough current.
    But, repair concerns aside, I’d still take the worst Meaco fan over anything from D**on.
    Mr_Mistoffelees, Arboreal and Ice Tea like this.
  6. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Still happy with my (non-battery) Sefte 10", picked up at Costco a year or two back.
    At least, I've had it long enough to need to replace the CR2032 in the circular remote.
    Ice Tea likes this.
  7. mrlongbeard
    mrlongbeard Multimodder
    31 Jan 2010
    I've got 3 already (8" desk, 10" desk & 10" sefte pedestal) , that's enough, they lose a point on having polymer nut securing the fan blades rather than having a metal insert, and another point for having simple IR remotes that operates all of them, but for now I'll stand with what we've got and hold off buying an AC unit until winter.
  8. Mr_Mistoffelees
    26 Aug 2014
    I think the word ‘shite’ sums-up our old Dyson pretty well. Is a big floor standing one which now makes a lot of noise, whilst generating only a very gentle zephyr.
    IanW and Ice Tea like this.
  9. veato
    veato I should be working
    15 Jan 2010
    Tried the sister-in-law's Dyson bladeless thingy the other day. Sure it looks fancy and can do heat when things eventually cool down but honestly it wasn't doing nearly as much air shifting as my 'basic' Meaco
  10. b1g-d0g
    b1g-d0g Multimodder
    30 Sep 2001
    That's a cool offer :rock:
  11. Nexxo
    Nexxo Rotate Your Owl For Science
    23 Oct 2001
    Probably needs cleaning. The fine inlet holes in the base get clogged easily, as does the filter.
  12. Mr_Mistoffelees
    26 Aug 2014
    Was thinking about looking at how to get inside it but, the Meaco’s have rendered it redundant.
    Byron C likes this.
  13. Byron C
    12 Apr 2002
    The only thing that annoys me about cleaning Meaco fans is the insistence on screwing on the front grille. That means I need tools, which makes it a little more than a “I’m already vacuuming, I might as well do the fan while I’m at it” job (yes, I know it’s only a screwdriver, but this is a house with to ADHD adults who already struggle to keep on top of cleaning, and if you put barriers in front of a task for people with ADHD then you significantly diminish the chances of that task being done). Other than that, they’re a doddle.
  14. mrlongbeard
    31 Jan 2010
    Yeah that's annoying, but only once, remove screws, throw screws in spare screw tin never to be used again.
  15. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    I reckon Meaco fans are probably a lot easier to clean than most, yeah you need to remove a couple of screws but at least the whole thing is designed to be disassembled for cleaning by users which is more than can be said for some consumer fans.
    Only annoying bit for me is remembering that the little retaining nut for the fan blades is reverse-threaded. You'd think years of working on bikes where reverse threads are pretty common (non-drive side pedals, for example) would make it easier to remember, but no!
    Edit: and yes, I know, it even says on the nut which way to turn it :D
