Electronics meanwell power supply help
Discussion in 'Modding' started by Ouikikazz, 2 Feb 2003.
  1. Ouikikazz
    Ouikikazz What's a Dremel?
    13 Apr 2002
    ok, call me stupid and all but how to do you power one of those meanwell switching power supplies? Like with what kind of wires/source
  2. cpemma
    cpemma Ecky thump
    27 Nov 2001
    If yours has connectors like this one, connect mains to line, neutral and earth, take your output from + and -, set the switch to local mains, 110v or 230v, stand well back and switch on.
    Use a mains lead to suit the wattage, in the UK 5A 3-core would run most.
    If yours isn't like that, post the model number.
  3. Ouikikazz
    13 Apr 2002
    I have the MEAN WELL S-320-12, I know there are three lines to plug into but i'm so accustomed to using a AC adapter type cable I have never used one of these which leaves me to wonder where to get power from.
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    These psus are designed to go inside a case where fingers can't touch the high-voltage connectors.
    Then the supply wires go, via a switch, to a panel-mounted male mains connector, like on the back of a computer psu, or to a lead out of the case (through a grommet) to a mains plug and wall socket.
  5. Ouikikazz
    13 Apr 2002
    got any pics of this?
  6. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Wall socket (UK)
  7. Ouikikazz
    13 Apr 2002
    appreciate the help
    I know what a wall socket looks like ;p I meant a picture of the meanwell power supply hooked up to a wall socket.
