Peripherals Mechanical Keyboards
Discussion in 'Hardware' started by Raptor77, 27 Dec 2011.
  1. JaccoW
    JaccoW Overspender on keyboards
    30 Apr 2009
    How did I miss this so far?!?
    A 66% board with hot-swappable switches, leds, carbon fibre plate and an Fn key under the space bar... GIMME!
  2. fuus
    fuus Rocking All Year Christmas
    4 Dec 2010
    Anyone interested in buying my sprit board? I payed £120, so ideally looking to get that back...
    87%, MX Clears, full set of orange LEDs, 4mm Clear plate.
  3. shrop
    shrop El Jefe of Sleeving
    22 Jul 2011
    wanna do a swap?
  4. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    I dont understand why people want to change switches and want switch swap plates etc.
    Just buy more keyboards :D
  5. crazyg1zm0
    crazyg1zm0 Minimodder
    20 Feb 2007
    That would be awesome Margo.
    Ca't wait to get the JD40 though cant make it immediately but will be itching to get to it
  6. Yslen
    Yslen Lord of the Twenty-Seventh Circle
    3 Mar 2010
    Buying more keyboards is great if you're rolling in cash :p
  7. fuus
    4 Dec 2010
    What's on offer shrop? I'm guessing a 60% which im not really into, feel free to try and tempt me though
  8. shrop
    22 Jul 2011
    PM me breh, lets talk, really want to mix it up at the moment :)
    I can offer some stuffs
  9. Anfield
    Anfield Multimodder
    15 Jan 2010
    Yep its a bit strange, how often does your switch preference change? Someone new to mechanical keyboards might want to try different ones, but those probably aren't the people willing to drop $300 on a keyboard in the first place.
  10. Yslen
    3 Mar 2010
    I find there's something to like about all switches. Also, getting a board with switch opening notches means I can use custom springs, vintage black sliders etc without desoldering. I imagine it seems odd to Margo because he can melt solder with a single glance from 20 paces :p
  11. Xaine
    Xaine Death... destroyer of brain cells
    19 Sep 2012
    Anybody know of a decent mechanical keyboard, preferably red switches though wouldn't mind trying blue, would be used almost entirely for mmo gaming not worried about size though price is the major issue, I want to get into mechanical keyboard though don't really know where to start.
  12. JaccoW
    30 Apr 2009
    I own 4 boards with MX Clears right now, 5 if you count the numpad. :D
    For me it wouldn't really be the hot-swapping but I just really like the layout for a work board. And there is something intriguing about having a CF plate. ;)
    No cash to drop on something like this just yet though. :rolleyes:
  13. Shirty
    18 Apr 1982
    Call me mad, but blues are my favourite at the minute. The click epitomises everything I believe a mechanical keyboard should stand for.
    But I have love for all MX variants :)
  14. Xaine
    19 Sep 2012
    In theory blues sound perfect for mmo gaming as the click while satisfying I imagine would provide full confidence a spell/attack has been initiated.
  15. Shirty
    18 Apr 1982
    I suspect that was Razer's logic with the BlackWidow. Considering a huge part of their customer base are probably MMO players it was probably not quite as bad a decision as a lot of people thought it was at the time.
  16. GeorgeK
    18 Sep 2010
    I can see both sides of the argument - the cutouts do mean that the switch tops are more likely to come off when swapping keycaps but I think they're invaluable whilst you're sorting out preferences - for example with my Poker I went from clears (which I found a little heavy) to 62g ergo-clears (which weren't quite heavy enough to avoid some sticking issues even lubed) to 65g ergo-clears (which are amazing btw) all without having to desolder. I'm not going to be changing it any more though so the cutouts are now redundant :)
    I do like clicky boards (buckling spring > * btw) but I find blues to just be a little too light - greens and blears are nice though :thumb:
  17. Xaine
    19 Sep 2012
    Your comment prompted a search for the Razer, I then veered off and found what I think may be my first mechinal keyboard, it's affordable, a brand that carries weight and reviewed very well http://www.overclockers.co.uk/showproduct.php?prodid=KB-013-CH&tool=3
    Simple, elegant, ello sexeh!
    After 6 years of an awful Acer laptop keyboard though I think a dell dome board would make me happy :D
  18. Xaine
    19 Sep 2012
    Hmmm, are greens and clears higher g clickys then?
  19. Shirty
    18 Apr 1982
    The G80-3000 is one of the original and best mechs, so it'll serve you well. Quite flimsy though, so no rage-quitting allowed.
    Greens are supposed to be used as the spacebar switch on blue boards, but many people like the additional weight (80g vs 50g for the blue) as it reminds them of the more vintage clicky keyboards from IBM.
    Clears don't click, but are heavier than blues and have a very pronounced tactile bump. If you master the art of typing on clears you will never bottom out the keys, which can actually save fatigue on your fingers versus some of the lighter switches.
  20. Xaine
    19 Sep 2012
    That is very good to hear, also I don't rage unless I get huge lag spikes in the last 10 seconds of an intense no mistake boss fight, considering the setup I'm building that is very unlikely to happen again and if it does I won't be at the crap out a it like I may have an annoying lappy board :D
    Aaah, the weight shouldn't be a problem as I'm used to the lappy board that has near zero weight, also I might have a good chance at not bottoming out as the board is like a mm give, other than that its my hudl.
    Only thing that'll concern me is over compensating in force to never miss a key due to the extended distance while I'm learning to touch type on the new layout.
