Peripherals Mechanical Keyboards
Discussion in 'Hardware' started by Raptor77, 27 Dec 2011.
  1. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    All the resistors you need are 0805 (2012) size smd resistors.
    oh - the SMD LED (that go on the bottom) are 1206 (3216) size.
    0805 and 1206 are imperial sizes - metric is 2012 and 3216 respectively.
  2. crazyg1zm0
    crazyg1zm0 Minimodder
    20 Feb 2007
    Ok I am getting more confused now.
    so to build my Ctrl60 board i will need the following
    Switches
    LED's
    1N4148 diodes
    50 x 133 resistors
    65x 470 resistors
    stabs
    I think thats right so my diode order would be 40x 133 resistors as i ordered white LEDS and 65 470 resistors (all 8050)
    also what do you mean by the SMD LED?
    Oddly when I look around for the SMD resistors all i seem to find are ones with a range or 0 - 10k not specific resistances
    e.g: http://www.ebay.co.uk/itm/100x-SMD-...mponents_Supplies_ET&var=&hash=item3cd9481aeb
  3. Margo Baggins
    28 May 2010
    The LED that go on the bottom of the pcb are not through hole LED, they are SMD LED.
    Don't go on ebay for resistors :p get them from here https://cpc.farnell.com/ if you search "0805 470" then it will bring up loads.
    though on that ebay link there is a drop down to choose the resistance.
  4. crazyg1zm0
    20 Feb 2007
    Ah cheers for the info Margo Massive help.
    and I didnt even Know I would need an SMD Led
    Also I cant find 133 Resistors on there at all which is odd
  5. Margo Baggins
    28 May 2010
    I can never find 133's either, but those are the ones that GON suggests - you could probably get away with 120 but I've not tested that.
    You don't have to use SMD LED you could leave them off, if it's not going in a GON case, I would of thought there would be little gain having the underside LED.
  6. crazyg1zm0
    20 Feb 2007
    I Will keep looking for 133's then as its a Gon board and i would rather be safe than sorry and for now im not going to bother with smd I want to just get it sorted.
    I will eventually get a custom case where the sides are metal and there's a hole in the bottom which is covered with clear acrylic so you can see the CTRL alt logo
  7. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    Hello everyone!
    Not looking to derail this awesome thread, but just to say we're visiting Cooler Master HQ atm with access to a number of product managers. If you've got any mech keyboard related questions (or anything else related to their product line), please feel free to post them in the thread here:
    http://forums.bit-tech.net/showthread.php?t=279240
    Cheers!
  8. Margo Baggins
    28 May 2010
    the [CTRL] Alt is on the top - under where the switches will be, you won't really see it if you have a plate, if it's in a plateless setup then you would see it through the switches.
    Couldnt really go on the bottom as there is a silk screen on the bottom that tells you what to put where, and that's quite important info so it had to go on the top.
    Infact - there is loads of 133 at my usual supplier farnell, (not cpc their daughter store) http://uk.farnell.com/jsp/search/br...skipParametricAttributeId=&prevNValues=215515 problem with farnell is it's min 20 quid order, unlike a fiver at cpc.
  9. crazyg1zm0
    20 Feb 2007
    Looks Like I am going plateless then haha.
    And I found some 133 0805's on aliexpress that a mate of mine suggested ordered 200 to be sure came to £2 so will not complain
  10. JaccoW
    JaccoW Overspender on keyboards
    30 Apr 2009
  11. Margo Baggins
    28 May 2010
    YES haha, I have literally just filled out the form before seeing you post here. I just know, that if I don't get it, I will kick myself.
  12. JaccoW
    30 Apr 2009
    Haha, NO Margo, we need you for board construction! :p
    Cyan is awesome, but because this is ran by Feng it only appears in his subforum. It needs more exposure. I want those Pink mods to make a toned down GMK Miami set :D
  13. Yslen
    Yslen Lord of the Twenty-Seventh Circle
    3 Mar 2010
    Tempted by Cyan, but I want other upcoming sets more...
  14. JaccoW
    30 Apr 2009
  15. Hzza
    Hzza Minimodder
    15 Apr 2013
    Also tempted by cyan but I have no money and 2 kids...if only there was a way I can get 2 money and no kids.
  16. Yslen
    3 Mar 2010
    CTRL ALT is, I believe, running hyperfuse again in the near future. I'm saving my pennies for that :D
    The Deep Space DSA IC on PMK also looks good.
  17. Margo Baggins
    28 May 2010
    hype. GMK hyperfuse too.
    soon ;)
    I want to use the purple mods with the cyan alphas, and the cyan mods with WoB, I think that will be tremendous.
  18. asura
    asura jack of all trades
    22 Apr 2009
    I'd be interested if it wasn't for the handbag...
  19. Yslen
    3 Mar 2010
    exxxxxxxactly :D
  20. JaccoW
    30 Apr 2009
    Serious HYPE! Ha, I forgot about that one.
    I'm really looking forward to the rumoured GMK Miami as well.
    What I do know is that I will be picking up Ivan's Dolch and various other goodies tomorrow afternoon! :rock:
    The delivery guy came by but I didn't have enough cash on hand to pay the import tax.
    But GMK packing tape doesn't lie. :D
