Peripherals Mechanical Keyboards
Discussion in 'Hardware' started by Raptor77, 27 Dec 2011.
  1. David
    7 Apr 2009
    OK question for the KB techies...
    Is it possible to reprogramme a keyboard to enable the backlit my default? My Race defaults to off when first powered on. If it is possible, how do I access/backup/modify keyboard firmware?
  2. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    for the most part you can't. For the most part, you can't very easily get it into the boot loader. Potentially there is some options to do it over serial (isp) but more often than not there will be a bit (as in, a "bit" - like a byte) of security in the firmware, which will make it pretty hard to reverse engineer unless you are a dab hand at software engineering. you probably won't be able to do it without some other bits of kit, some kind of hardware device to do the serial stuff, like an arduino or something.
    First challenge would be working out how you can get firmware on and off the board, repetitively and without bricking the board. Second challenge would be successfully decompiling the firmware, and working out what's going on, and changing it and then being able to flash the changed firmware onto the board, as i'm guessing there might be some kind of checksum somewhere - so, you would maybe have to write your own software to actually flash the board.
    So basically no :)
  3. David
    7 Apr 2009
    Fair enough :)
    It isn't a problem - I'd just like the option to do it or reconfigure a dipswitch to enable it, if it was an easy hack. I didn't know if some KB genius had already figured it out, and it could be accessed by hooking it up to a PC or tablet OTG port and running a handily compiled piece of software; or something equally brilliant and simple.
    Cheers Margo.
  4. Margo Baggins
    28 May 2010
    I'm not really too clued up on the race.
    I know someone has done it for the CM Rapid-I (whatever the lightup ones called), well, they have broken the firmware and written some of their own with a resilient upload/download method. So it's possible, just takes a software guru!
    EDIT: Actually, on reading up on KBT boards they quite often use controllers that are one time flash which means you won't be able to change the firmware.
  5. David
    7 Apr 2009
    I imagined it belonged to a family of boards that likely shared a common basic firmware, with tweaks for different feature sets
    Yeah, I saw the video of someone playing snake on the rapid-i. :lol:
  6. Margo Baggins
    28 May 2010
    I just spent ages writing an edit above as someone selfish phoned me up!
    KBT seem to use chips that are one time flash, so there is no bootloader or other way to flash them really, so there is no way to change it :(
    The rapid-i uses quite a common feature rich controller which is why it can be exploited like that.
  7. David
    7 Apr 2009
    Unless you could replace the chip with an EPROM or some such similar bit-o-silicon? :D
    Yeah, well, it was worth asking - I'll be pulling it apart soon to fit it with browns and maybe try that LED SIP mod, so I thought why not go the whole hog.
    Where do you buy your white LEDs from? I have one that isn't working and a few that are dimmer than those around them.
  8. Margo Baggins
    28 May 2010
    I only really use 2x3x4 rectanglular LED or 1.8mm dip LED, neither of these are standard LED so you would have to replace them all! The 2x3x4 I get from a seller called bright components on ebay, the 1.8mm LED I buy from a german seller on ebay, until my big order or 1.8mm LED arrives from the far east.
  9. David
    7 Apr 2009
    Thanks, I'll give em a look over.
    So, if I want to replace just a few, I'll need to use the standard round 3mm LEDs?
  10. Margo Baggins
    28 May 2010
    Yeah just 3mm ones, the ones without a collar at the bottom work better.
  11. David
    7 Apr 2009
    Pro tip!
    Cheers, kind sir.
    [edit] Ordered a bunch of flangeless ones
  12. JaccoW
    JaccoW Overspender on keyboards
    30 Apr 2009
  13. JaccoW
    30 Apr 2009
    Got my very first Brobot!
    Icestrom is next for those who didn't win this round.
  14. Margo Baggins
    28 May 2010
    I won three kings gold and snowmando :D
  15. JaccoW
    30 Apr 2009
    SWEET! I'm jelly of that Snowmando. :p
  16. Margo Baggins
    28 May 2010
    Yeha the snowmando is amazing!
    I think I have over 10 bros now, maybe 11 with these new two. I think I need 4 more to fill the top row on my hhkb.
  17. jinq-sea
    15 Oct 2012
    I MISSED OUT ON THE DAMN SALE! DAMN MY BUSY REAL LIFE!
  18. adrock
    adrock Caninus Nervous Rex
    5 Dec 2006
    WTF guys, where's the mechanical keyboard christmas spirit!
    Merry Christmas everybody!
  19. JaccoW
    30 Apr 2009
  20. JaccoW
    30 Apr 2009
    Found some nice vintage Cherry doubleshots for just €25. ;)
    GH crosspost
