Peripherals Mechanical Keyboards
Discussion in 'Hardware' started by Raptor77, 27 Dec 2011.
  1. jinq-sea
    15 Oct 2012
    Has anyone got a ten keys' worth of browns? I need them for the weekend
  2. adrock
    adrock Caninus Nervous Rex
    5 Dec 2006
    OH IT'S ON! :D
    I see the offer of two japan caps and raise you two RoW 1.25 mods from the Klaxon groupbuy, previously unused:
    In fairness, the red might be a little darker so it's your call.
  3. Kronos
    Kronos Multimodder
    6 Nov 2009
    Yes please, how much?
  4. adrock
    5 Dec 2006
    you can have them. owing to previous impulsive behaviour i actually have four; allow me to repent a little :D
  5. Kronos
    Kronos Multimodder
    6 Nov 2009
    Thanks kind sir I will pm you my address.
  6. Hzza
    Hzza Minimodder
    15 Apr 2013
    I have some blacks and/or clears I can spare, all out of browns though.
  7. SouperMatt
    SouperMatt What's a Dremel?
    10 Apr 2011
    Hi, just after some advice, I currently have a Coolermaster TK with black switches.
    I like the action of them but I'm after something that requires a bit less force, would I better with Red or Brown switches... or something else entirely.
    Also would like it to be relatively quiet.
  8. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    I like browns, reds I find too light given they have no tactile bump on them at all. Red's I also type on very loudly as I find it very difficult not to bottom out my stroke, thus there is a lot of noise from bottoming out the keys.
    I think you should look at getting browns, I think they are ace. I didn't used to, but recently they have become my switch of choice.
  9. SouperMatt
    10 Apr 2011
    Thanks, I have been looking at browns just because of the videos I've seen. Do you have any specific board recommendations?
  10. Hzza
    Hzza Minimodder
    15 Apr 2013
    Quickfires are decent enough, Duckys are also pretty good. Filcos are nice but don't have a lot of the features of the less expensive boards so can't really justify their higher cost all that much anymore.
  11. SouperMatt
    10 Apr 2011
    Yea I like the price of the Coolermaster boards but I don't like their branding, just want a completely plain board, I'm a bit weird like that!
  12. David
    7 Apr 2009
    I have some on order, Sam, but I don't know if they'll be here for the weekend.
  13. Shirty
    18 Apr 1982
    If you want completely plain, pick up a Ducky DK2108 Zero with browns. It'll cost you about £70, but it's just about the most vanilla looking budget mech (if you can call £70 budget).
    If you can stretch into the £100 and up range there are a few more options with better build quality and materials, but you'd have to be an enthusiast to move into that realm. Unfortunately my recommendation for vanilla at this price point is the Ducky G2 Pro, which I believe has gone out of production.
    If you can find a CM Rapid without branding (and can live with TKL) then they are really nice boards.
  14. Hzza
    Hzza Minimodder
    15 Apr 2013
    I think their "stealth" range are relatively branding light, the branding is a common complaint but is a load better than it was when they first came out!
    I think Ducky have/had a pro range that was relatively low key, might be worth checking out as well.
  15. Margo Baggins
    28 May 2010
  16. David
    7 Apr 2009
    Forget RGB, I'd just like the clear switch tops!
  17. Margo Baggins
    28 May 2010
    you can get them - those aren't official cherry tops, they are repros, I don't know where you buy them as I have never bought any people just send them to me with their stuff.
    Gateron switch GB - https://geekhack.org/index.php?topic=68943.0 some people think this switch might be a cherry mx beater.
  18. JaccoW
    JaccoW Overspender on keyboards
    30 Apr 2009
    It's really the dark grey sliders that make the clear switch tops and stickers stand out that much. I think I want to try out ghost blacks (or whatever you call clear springs with black sliders) on a next board.
    As for the clear switch covers: Various Group Buys and Techkeys had them.
  19. Shirty
    18 Apr 1982
    Have you tried any of them yet Matt?
    I'm interested in picking up 120 for an upcoming project but I can't be arsed to join GH just to enter the group buy and then never post again. If anyone's in, drop me a PM - I'll cover all costs.
  20. Hzza
    Hzza Minimodder
    15 Apr 2013
    I'll be dipping in for a boards worth I guess just to try something different. Not sure what flavour to go for just yet though, I'll need to do a bit of research but I'll probably plump for either the clears or the blacks.
    edit - I'm going in for 100 clears and 100 browns.
