Peripherals Mechanical Keyboards
Discussion in 'Hardware' started by Raptor77, 27 Dec 2011.
  1. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    The quickfir xt is now mine, for a decent price at 60 spondoolies posted. If anyone knows where I can get some cheap orings that be much appreciated.
  2. David
    7 Apr 2009
    PM your address, mate.
    I have plenty spare from a early, misguided flirtation with o-rings.
    Why anyone would spend their hard-earned on a mech board then spend extra to make it feel more like a rubber dome is beyond me.
    The_Crapman likes this.
  3. Shirty
    18 Apr 1982
    Also, whether you like the feel of o-rings or not (I despise them), they do nothing to silence the return sound with is about 80% as loud as the clack when bottoming out in normal typing.
    I'm with Dave, it's mental. Kills the feel and doesn't kill enough of the noise to make it worthwhile. However, some insane people swear by them so I guess it's only fair to let people make up their own minds :)
  4. Guest-44432
    Guest-44432 Guest
    See, well I guess because you guys have done the trial and error, use newbies wouldn't of known.
    So you guys don't rate them at all? :)
  5. Shirty
    18 Apr 1982
    You have to try them, but no I don't rate them even a little bit.
  6. David
    7 Apr 2009
    Yes, please draw your own conclusions, but I'm certainly not a fan of them.
  7. GMC
    GMC Minimodder
    26 Jun 2010
    I still keep a couple o rings on some keycaps but not on anything normal - some of my metal caps benefit.
  8. The_Crapman
    5 Dec 2011
    Thanks for the very kind offer dave. I don't want to bother you with the hassle if it's not particularly beneficial. My main reason for going mech is to try and avoid bottoming out and save my poor stubby fingers from the abuse my furious typing provides. Considering that, adding orings is likely to be counter productive as it will shorten the travel, so I will see how things go without first.
    Thanks again ace. (what a guy)
  9. Guest-23315
    Guest-23315 Guest
    Havent seen this thread and remember being awful snooty about Mechs back in 2012 when the craze first started hitting..
    Just to say, I'm still on the same K60 w. Reds I won three years ago, and am so addicted to it I also have one at work. That being said, I don't understand how some of you guys can survive without numpads on your keyboards..
    I suppose if you're purely using you system for gaming it makes a bit more sense, but otherwise I really don't.
  10. Guest-44432
    Guest-44432 Guest
    It's finally arrived :)
  11. The_Crapman
    5 Dec 2011
    That is one good looking keyboard. Shame about the naff logo at the top. It's what I'd probably get for at home if I wasn't saving for Sweden and a new mobo.
    Which rat mouse is that? I have a 7 and love the pinky shelf.
  12. Shirty
    18 Apr 1982
    Setting your sights high then Crappy, Sweden's nominal GDP is over 500 billion dollars.
  13. David
    7 Apr 2009
    I'm not suggesting you shouldn't try them, mate - I'm saying that, my way, at least it won't cost you to find out if you like them or not.
    The offer remains, regardless. :)
  14. The_Crapman
    5 Dec 2011
    Oh I'm not buying. I'm invading :rock:
    Thanks. I shall give it at least a couple of weeks use and see how things are before I start tampering with it. There weren't any on the ones I've tried, i thought it would help with the bottoming out by cushioning the blow. But if my ultimate goal is to stop bottoming out then not having them there will probably be an advantage.
  15. JaccoW
    JaccoW Overspender on keyboards
    30 Apr 2009
  16. Shirty
    18 Apr 1982
    How is this in any conceivable way new?:
    Jinq, I'll be interested to hear your opinions once yours arrives. Insubstantial wear to the caps, but I'm still far from impressed.
    :sigh:
  17. adrock
    adrock Caninus Nervous Rex
    5 Dec 2006
    well if you only just got it, then it's new, right?
    that does look a bit rubbish, and pretty shady if sold as new. and by shady i mean a flat out lie.
  18. David
    7 Apr 2009
    That's not even the pad that was pictured - the Goldtouch logo is a different colour - I'm pretty sure that listing shows the 077 (same as my pad), what model do you have there? Does it still have the USB ports on either side?
  19. Shirty
    18 Apr 1982
    That's the old KeyOvation logo, which I'm sure was changed some years ago.
    It's the correct model though, with the USB hub and MX browns. But it ain't new (even old new stock would have been fine).
  20. jinq-sea
    15 Oct 2012
    New? My ar*e! I'm really peeved! eBay strikes again...
    Sent from my iPhone using Tapatalk
