Peripherals Mechanical Keyboards
Discussion in 'Hardware' started by Raptor77, 27 Dec 2011.
  1. GMC
    GMC Well-Known Member
    26 Jun 2010
    Fair enough. I've bought stuff from feng before and he appears on geekhack as well. I'd email and ask him if he can mark the value down for shipping if he has something you want but are concerned about the additional hit on import
    Edit to add mass drop keys arrived. Both sets complete and an extra Y key .
  2. Kronos
    Kronos Well-Known Member
    6 Nov 2009
    I picked up an IBM KB-7953 for the princely some of 50p. Needs a bit of a clean. Is it easy enough to strip down for cleaning purposes? And would it be worth anything if I did?
  3. Kronos
    6 Nov 2009
    Before I go stripping it down, Plugged the KB ps2 into a USB adapter and am getting unknown device and not much else.
    Have I frittered away my 50p or can something be salvaged?
  4. Big_malc
    Big_malc Well-Known Member
    7 Sep 2010
    some of them adaptors esp the strait connection type don't all ways convert signal properly if at all
  5. Kronos
    6 Nov 2009
    Is there a solution?
  6. GeorgeK
    18 Sep 2010
  7. Kronos
    6 Nov 2009
    Cheers George.
  8. GeorgeK
    18 Sep 2010
    No worries - I have two boards (well one IBM keyboard and one numberpad) that I run through them and they never skip a beat - plugged in through the cheaper ones they either aren't recognised at all or they come up with the same error you're getting "unknown device"
  9. Kronos
    6 Nov 2009
    Discovered that my secondary PC has a PS2 port KB working perfectly. Now to take it apart to clean.
  10. GeorgeK
    18 Sep 2010
    Good news - worth checking that it actually works before putting in the effort of taking it apart!
  11. Kronos
    6 Nov 2009
    Stripped and casing cleaned, key caps enjoying a final spin.
  12. Kronos
    6 Nov 2009
    It cleaned up well.
  13. GMC
    26 Jun 2010
    Looks nice. I'd guess it just doesn't speak USB so won't work no matter what converter you try to run it through
  14. Big_malc
    7 Sep 2010
    Kronos did you wont one of the ones GeorgeK link up going to order some don't mind grabbing another if you wont
  15. GaryP
    GaryP RIP Tel
    31 Aug 2009
    I could do with one malc for my dell keyboard here. How much would I be looking at to get one sent here ?
  16. Big_malc
    7 Sep 2010
    I got 3 coming so 2 are spare atm seems to be last of there stock but $5.00 is £3.37 + postage to Arse end of Nowhere :D
  17. Kronos
    6 Nov 2009
    Total is what then Malc?
  18. Big_malc
    7 Sep 2010
    going be small package so few quid postage to Edinburgh say £5 may be £6 tops
  19. Kronos
    6 Nov 2009
    OK put me down for one please mate.
  20. Big_malc
    7 Sep 2010
    hmmm no idea why but order has been cancelled and refunded looks like out of stock but cant be sure
