Peripherals Mechanical Keyboards
Discussion in 'Hardware' started by Raptor77, 27 Dec 2011.
  1. GeorgeK
    18 Sep 2010
    Boards don't tend to lose too much value tbh - maybe knock off 10% or 20% if you wanted a fast sale
  2. Shirty
    18 Apr 1982
    They revised the Goldtouch pads when Windows 7 was released, grab a later model or YMMV.
  3. Impatience
    Impatience Minimodder
    6 Apr 2014
    Think I may opt for a shiny new board then! Any good suggestions for a full (non giant macro sections ala Corsair K95) Brown switch board? Was looking at the current Ducky boards, but they use these weird feet now.. And the Shine 5 RGB looks great, but it has the same casing! :wallbash:
  4. David
    7 Apr 2009
    My Rapid-i has lost it's first LED. Looks like this is a common fault with them.
    Debating whether to RMA or just crack it open and replace the damned thing to avoid buggeration. I know it'll kill the warranty, but I fecking hate waiting for RMAs.
    [edit] stuff it, I have spare boards lying around - I'll use one of them and return the thing.
  5. LennyRhys
    LennyRhys Oink!
    16 May 2011
    Is this CM skimping on component quality? Shame on them, especially on such a high-end and expensive board!
  6. GeorgeK
    18 Sep 2010
    Filco? Pricey but awesome
  7. adrock
    adrock Caninus Nervous Rex
    5 Dec 2006
    this. I've not looked back since i got my filco with browns. it was relatively expensive but i'm quite heavy handed (clumsy) and it's more stable than anything else i've tried.
  8. GeorgeK
    18 Sep 2010
  9. law99
    law99 Custom User Title
    24 Sep 2009
    I've been using a tenkeyless Corsair thing with reds for a long time now. Quite like it to be fair. I still have a das keyboard pro, but haven't used it in ages as the space on the desk was key. I'd like a filco myself.
  10. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    :lol:
  11. Impatience
    6 Apr 2014
  12. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    Quick question for you experts. I've got a CM Storm Quickfire Rapid with blues and Massdrop has some ABS double-shot keycaps for a pretty reasonable price. I'm on the fence about picking up a set, just to change things up. Are the ABS keycaps compatible? They say they work with all cherry switches, but I just want to double check before I pull the trigger.
  13. David
    7 Apr 2009
    ABS is just the material the caps are made from - The caps will fit MX switches no problem.
    I've had a couple of sets of the DS caps from Massdrop - they're fine as long as you have an ANSI layout.
  14. mansueto
    31 Aug 2007
    @Spreadie, cheers for the quick response! Upon further inspection they're all sold out unless you pay extra for the boxed versions. At least for next time I'll know.
  15. JaccoW
    JaccoW Overspender on keyboards
    30 Apr 2009
    Seems like Geekhack won't be online for a few days...
  16. Yslen
    Yslen Lord of the Twenty-Seventh Circle
    3 Mar 2010
    Yup, that's pretty annoying.
  17. JaccoW
    30 Apr 2009
  18. GeorgeK
    18 Sep 2010
    I entered - has anyone heard anything yet?
  19. JaccoW
    30 Apr 2009
    Nope, you can check your ticket on the website. If you didn't win it will just say "Submitted"
  20. GeorgeK
    18 Sep 2010
    Yeah - I didn't get anything :( I really want a Brobot for my IBM board/s...
