Peripherals Mechanical Keyboards
Discussion in 'Hardware' started by Raptor77, 27 Dec 2011.
  1. Byron C
    Byron C Over-reacting and over-analysing since 1982
    12 Apr 2002
    Disclaimer: I haven't had a look at the design files, so I'm not sure what sort of work is actually required. However... if this is a laser cutter job, then a friendly local hackspace might be a good shout.
  2. TheBlackSwordsMan
    TheBlackSwordsMan Far over the misty mountains cold
    16 Aug 2009
    Yesterday, the clumsy me dropped a bottle of water on my Corsair K70. 10 minutes later it started to behave abnormally while I was doing LOL Arams with friends. It was typing frenetically by itself and flashing as if possessed.
    So I took it apart, put it in a large plastic container and poured about 1-2 pounds of rice over it. Less than 24 hours later, it was dry and behaving normally. * Thumbs up
    David likes this.
  3. Andy Mc
    Andy Mc Modder
    23 May 2002
    Good call. I think there is one in Swindon.
  4. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    I built a new keyboard
  5. David
    7 Apr 2009
    Holy sh!t, Gordon's alive!
  6. Margo Baggins
    28 May 2010
    Arguably one of the nicest sets of PBT Dyesub Alphas you can get - https://www.ebay.co.uk/itm/Electric-Typewriter/184700295438?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649 going for a song. I would buy... but I have 3 sets already and not enough mods for them all.
    and some royal alphas - https://www.ebay.co.uk/itm/Vintage-...392286?hash=item3db74eaf5e:g:qgoAAOSwLlVgDzZl
    and another set of royal alphas - https://www.ebay.co.uk/itm/Royal-Al...968107?hash=item56f41164eb:g:vJ4AAOSwDYJgK02F (this has the green "code" keycap which is a fairly saught after keycap)
  7. BeauchN
    BeauchN Modder
    5 Apr 2011
    That is a lovely colour for a case!
    I've spent much more on mech keyboard bits recently that PC hardware (admittedly that's mainly because PC hardware is non-existent!). My last build was the Tokyo60 from Drop, with lubed and filmed Glorious Pandas and some PBT Red and White caps...
    Margo Baggins likes this.
  8. Margo Baggins
    28 May 2010
    My whole life is spending more on mech keyboards.....than anything else! :D :D
    What do you think of your Tokyo60? it's on my list, but I'm not sure if I will like the plastic bottom or not. I think if I bought it I would just sleeve it and put it in storage which seems silly. But I like the top of the case (but have 1x mx hhkb and 2x topre hhkb....)
    Also what do you think to those PBT caps? I keep seeing those for 40ish quid a set and I keep nearly picking up the muted ones or the 9009 ones, but the CTRL really upsets me! If it said "control" I think i'd have bought by now.
    My KBD8x has Boba U4T switches (which are amazing) and Cherry PBT caps.
  9. BeauchN
    BeauchN Modder
    5 Apr 2011
    I like it, I fancied trying something a bit different, and it's certainly that. It forces me to think because of the function placement and layer, and with the 'control' being in place of the 'caps lock', but it works and if I used it more often I'd probably pick it up really quickly. My daily driver is either my Tofu60 with a mix of 65 and 78g Zilents, or Drop Alt with Silent Alpacas.
    My Tokyo case is all aluminium, the only plastic is the optional diffuser strip between the two halves of the case. I've got to say, it is pretty thocc-y with these switches in! The caps are the $45 Artifact Bloom set from Drop. for the price they are really good. Smooth but not slippy, legends are clearly and consistently printed, and no dodgy mouldings that I spotted. One benefit of the HHKB layout is that the 'control' button actually says control, not CTRL! :grin:
  10. Gareth Halfacree
    Gareth Halfacree WIIGII! Staff Administrator Super Moderator Moderator
    4 Dec 2007
    First thing I do on a fresh install, if I'm not using my Model F which has Control in the correct place as God intended, is this:
    BeauchN and Margo Baggins like this.
  11. Margo Baggins
    28 May 2010
    I have a few old old coolermaster boards which I have hard modded by cutting the traces and running jump wires to move the CTRL to the CAPS position. It really is the best way to type.
    Gareth Halfacree likes this.
  12. Margo Baggins
    28 May 2010
    Also have you seen the new model F's are finally getting to people? model f keyboards - I've ordered and thrown a lot of money at them for a kishy. Who knows when it will arrive.
  13. Gareth Halfacree
    4 Dec 2007
    No, I hadn't seen 'em - but sure enough, there they are! Tempting, but I'd want to hear how much like a real Model F they feel first. Let me know your thoughts when yours tips up, will you?
  14. Mr_Mistoffelees
    Mr_Mistoffelees The Rotary Cat.
    26 Aug 2014
    Which is the preferred material for keycaps, doubleshot ABS or PBT?
    My Filco needs to have purple keycaps with yellow legends...
  15. Gareth Halfacree
    4 Dec 2007
    Personally, I prefer PBT. Feels better under the fingers, is heavier, more solid. That said, a lot of "PBT" keycaps are actually just ABS, so be careful if paying a premium.
  16. Margo Baggins
    28 May 2010
    Literally the truth - about 10 years ago you would be hard pushed to find any doubleshot PBT caps - now on chinese sites, millions of PBT doubleshot keycaps.... surprisingly like Gareth says a lot of these are actually ABS.
    I like Cherry ABS doubleshot caps, or Cherry PBT dyesubs. As a result I also like GMK doubleshot ABS caps. I don't really use anything else.
    You're very unlikely to find any cherry pbt dyesubs set for less than £200, and I think 100% unlikely to find one that will fit a filco! As they're all 1.5x mods, I don't think they made any 1.25x sets which are pbt dyesubs, and I don't think any windows keys exist at all as pbt dyesubs.
    I have a set of Purple + Black caps that would probably fit on your filco, but I imagine they're worth loads as they're an ancient SP set by todays standards.
    The other problem with quite a lot of the modern chinese pbt sets is they ship with no texture - they are smooth PBT, this is weird to me. Some people like it, but not me.
  17. Mr_Mistoffelees
    26 Aug 2014
    What I found, that I like the look of, is a set of ABS doubleshot caps, in purple with yellow legends, on an American site. They have no stock but, I think I might email them, to see if they expect more stock and, if they deliver to the UK.
  18. Margo Baggins
    28 May 2010
    looks at these - readily available and nice caps, https://www.amazon.co.uk/dp/B08BKSK..._dp_DQARMA5FXEPJRPXBBJXG?_encoding=UTF8&psc=1 - they have a purple and yellow set
    MadGinga and David like this.
  19. David
    7 Apr 2009
  20. MadGinga
    MadGinga oooh whats this do?
    19 Mar 2009
