Peripherals Mechanical Keyboards
Discussion in 'Hardware' started by Raptor77, 27 Dec 2011.
  1. IanW
    IanW Grumpy Old Git
    2 Aug 2003
  2. Gareth Halfacree
    4 Dec 2007
    Nope! I wrote about that on Hackster last week: Nick is very clear that the releases are source-available, not open-source.
    IanW likes this.
  3. Gareth Halfacree
    4 Dec 2007
    Diatec, the Japanese company behind the Filco brand, has gone bust.
    Might switch back to my Majestouch II for a bit, in memoriam.
  4. Mr_Mistoffelees
    26 Aug 2014
    Bugger! My Majestouch II is by far the best keyboard I have ever owned. I had hoped to stay with Filco, when it expires.
  5. Kehoe
    Kehoe Minimodder
    9 Aug 2015
    Not sure if this is the best place to ask, I'm after a wireless keyboard for downstairs, I don't want to break the bank, I just got a no name brand one and it's disappointing.
    My media center one is Bluetooth and the delay on it is unstable.
    I just require it to not be full sized, and ideally a back lit keyboard the room I'm in only had a table lamp.
    Like I said I don't want to break the bank it's going to be used only a few times a month, when I'm playing wow on TV ect
  6. BeauchN
    BeauchN Multimodder
    5 Apr 2011
    Breaking the bank is an easy thing to do with keyboards, especially mechanical ones!
    I think you just need a wireless keyboard that uses a 2.4ghz USB dongle for the connection. I’ve got an old Corsair K63 I use with the lap-pad attachment for gaming on the couch and there is no lag with that. A search on the rainforest brings up lots of options at all price points. I have had good experience with Keychron, but have heard good things about Royal Kludge and Red Dragon, which are usually cheaper.
    Byron C likes this.
  7. Byron C
    Byron C AKA “Sticky Equilibrium” on weekends
    12 Apr 2002
    Aye, something with a 2.4GHz dongle will be fine, bonus points if the same receiver can be used for both keyboard and mouse.
    Trying to find a “sofa gaming friendly” keyboard & mouse is a tall order. I’ve been looking a while… You’d be better off with something like a lap tray, or a sofa table/tray, and a “standard” KB & mouse. It’s a lot more flexible than trying to find something like the Lapboard. In that case, any one of an innumerable number of cheap 60% mechanical keyboards will be fine. 75% is probably the largest I’d personally want, if an F-key row is a necessity, and I’d say TKL/80% (e.g., full size Home/End cluster) is the absolute maximum you’d want - and that’s pushing it, tbh. The only real requirements are a 2.4GHz dongle instead of Bluetooth, and I would strongly strongly recommend hot-swappable switches. A quick search on the rainforest shows examples as low as £30.
    BeauchN and Arboreal like this.
