Peripherals Mechanical Keyboards
Discussion in 'Hardware' started by Raptor77, 27 Dec 2011.
  1. hamza_tm
    hamza_tm Modder
    10 Apr 2012
    so much for your master theme :)
    What's gonna happen to the other keys?
  2. imersa
    imersa Parvum Princess
    9 Apr 2009
    Was very close to getting one but went with my filco. I think with the shipping and caps deal I spent nearly as much!
    Maybe some day but I'm happy with my look rite now
  3. KidMod-Southpaw
    28 Sep 2010
    White letters and arrows, white esc, F4-F8, and Del- ect. Blank blacks everywhere else.
    What I do need to make it work are some blank grey modifiers, and they're not available. :(
  4. longweight
    7 May 2011
    They are with red on grey in the red alert GB.
  5. kenco_uk
    28 Nov 2003
    Might go for this one.. maybe. I'm weighing up whether to get one customised at source so to speak or whether it'd be cheaper to get a keyboard elsewhere and custom keycaps seperately.
  6. hamza_tm
    hamza_tm Modder
    10 Apr 2012
    Customized at source will get you exactly what you want.
    If you buy a board and get caps separate it works out about the same cost I think.
  7. longweight
    7 May 2011
    This.
  8. kenco_uk
    28 Nov 2003
    Hmm.. okay, good to know. Btw, my ocd is kicking in regarding the windows keys - I've tried to center them but they refuse to play ball. Anyone managed it?
  9. longweight
    7 May 2011
    No I have struggled with the keyboard creator though!
    Why not have all blank modifiers? Looks really nice and clean :)
  10. hamza_tm
    hamza_tm Modder
    10 Apr 2012
    Its just the way it's designed isn't the most intuitive.
    I haven't got access to it atm but iirc one set of options controls the vertical positioning independently of the other set of options that controls the horizontal positioning.
    Took me a while to work that one out :)
    Other than that I think you can open a default config and the Windows symbols should be all default?
  11. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    It's on the screen where you select the keys. Tick them, then look just under the keyboard at the bit saying "Alignment". Voila! :)
  12. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
  13. KidMod-Southpaw
    28 Sep 2010
    I know this is a very silly question, but I take it none of WASDs blank modifiers fit the Choc Mini?
  14. Virus44
    Virus44 What's a Dremel?
    2 Nov 2011
    Could anyone post the link so i customise a keyboard for myself ?
  15. happyhammer7
    happyhammer7 What's a Dremel?
    19 Oct 2009
  16. longweight
    7 May 2011
    www.wasdkeyboards.com
    Go from there :)
    Virus44 likes this.
  17. longweight
    7 May 2011
  18. happyhammer7
    19 Oct 2009
    Got £100 worth of amazon vouchers to use. Any suggestions for keyboards on there?
  19. Virus44
    2 Nov 2011
  20. GeorgeStorm
    16 Dec 2008
    The Race/Pure have recently become available on Amazon, I'd personally have a look at either of them, although it depends on what you want really.
