Peripherals Mechanical Keyboards
Discussion in 'Hardware' started by Raptor77, 27 Dec 2011.
  1. KidMod-Southpaw
    28 Sep 2010
    Why not keep it as a backup, backup, backup board? :D From what I heard they were actually quite nice to use!
  2. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Dell AT101W usually go from $5-20 depend on condition. The older winkeyless with blue switch can be worth more. If you are just going to toss it I am sure someone would give it a good home, they are a good board to try out Alps. Might as well let someone have it for cost of postage then...
  3. imersa
    imersa Parvum Princess
    9 Apr 2009
    haha no you don't! The Niqmods are mighty sexy though :p
  4. hamza_tm
    hamza_tm Modder
    10 Apr 2012
    it doesn't take any time at all, there is no "getting used to" period regarding typing feel, only if you go for a different layout
    step 1: get mechanical keyboard
    step 2: type on it
    simple as that really
    Teelzebub likes this.
  5. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    Step 3: have typing nerdgasm
    Sent from my HTC HD2 using Tapatalk
    imersa likes this.
  6. IvanIvanovich
    31 Aug 2008
    Well, not neccessarily true. If coming straight from domes to MX blues for example it could seem quite alien and may take some a bit of getting used to. There is a very huge difference in typing feel there going from stale gummy bears to retractable pen clickers... lol.
  7. imersa
    9 Apr 2009
    True... I went from dome to black and it felt just much better quality rather than anything els.
    I swear a lot of people I know that like blues only buy them because they make more noise. haha.
    Id recommend going blacks or browns and you wont have a problem with it feeling all alien!
  8. Yorkie
    Yorkie Minimodder
    22 Jun 2010
    Step 4: Spend all money buying stuff for it..
  9. longweight
    7 May 2011
    It took me about 3 days to adjust to my Filco, I am still getting used to the HHKB layout after a month!
    It's a very different typing experience, I find it hard to type on rubber dome boards now.
  10. longweight
    7 May 2011
    QFT.
  11. imersa
    9 Apr 2009
    +198281726
  12. hamza_tm
    hamza_tm Modder
    10 Apr 2012
    IMO Is there an amount of time when you feel typing is weird or unusual or that you need to adjust to it? Not at all, regardless of switch type it isn't like any mech switch will require more force than a rubberdome that you need to get used to or anything like that.
    You type and notice how much better it is, and that is pretty much all. No adjusting needed. No need to train yourself to type a certain way or anything, no period of discomfort inbetween.
  13. longweight
    7 May 2011
    Yes there is, it took me a few days to adjust to the actuation of the switch and I still struggle to go back to rubber domes. It's the same when switching between MX switches to me.
    In my opinion of course ;)
  14. hamza_tm
    hamza_tm Modder
    10 Apr 2012
    you had to adjust to the actuation? I just typed, did you feel uncomfortable before getting used to it? Was it a period of difficulty?
    And he's not talking about going back to rubber domes, he's talking about how long it takes to adjust to a mechanical after he jumps the bandwagon the first time.
  15. longweight
    7 May 2011
    It took a couple of days yeah and it the same as going back, they are both different and take time to adjust to.
  16. Drekz
    Drekz What's a Dremel?
    26 Jun 2011
    Alright, thanks for the info everyone. As mentioned, I've read up a lot about all the different key switches in order to see which one will be the most suitable for me. In the end, I decided to go with the cherry reds since they say it's really good for gaming (I'm not too bothered with the clicky feedback also from the other ones) - so that's a Corsair K60 inc! :)
  17. longweight
    7 May 2011
    Errr that is a mix of rubber domes and mechanical switches.
    Rip off at that price point!
  18. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    Step 5: Step replacing all keyboard every where with Mechanical Keyboards. :D
  19. Drekz
    26 Jun 2011
    mmhm yeah, that's the only the 'con' about the keyboard from what I saw, but I really like the quality control and everything about Corsair, so I guess I was drawn to that a bit.
  20. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Step 6: Take out a loan against your home to buy more mech board stuff
