Peripherals Mechanical Keyboards
Discussion in 'Hardware' started by Raptor77, 27 Dec 2011.
  1. Gareth Halfacree
    4 Dec 2007
    My second-hand Filco Majestouch 2 with Cherry MX Blues arrived today. Haven't had time to give it a proper run, but I'm typing on it now. First impressions: the keys require a lot less pressure to activate than the Model F, which can only be a good thing with regard to my knackered knuckle; the tactile click noise is surprisingly high-pitched, which might get annoying after a while; otherwise, everything seems tickety-boo.
    Oh, although I do have a tendency to double-shift - i.e. STart SEntence LIke THis - but I'm assuming that's just a question of getting used to the board.
    Still got my eyes out for some custom keycaps, but won't be ordering anything until I've spent some time with the board - don't want to spend cash if I'm going to end up selling the Filco and going back to the Model F after a week!
  2. GeorgeK
    18 Sep 2010
    I find blues to be a little too high-pitched too actually and also a little too easy to actuate (even though I love reds and browns - go figure eh?) Interestingly I found that initially I was double shifting with buckling spring - again it must be what you're used to!
    Did you pick up those non-windows modifier keys in the end?
  3. Gareth Halfacree
    4 Dec 2007
    Not yet. Found a place in the US that does *Amiga* modifiers - and also custom orders, and I'm *really* tempted to get the Commodore 'chicken-head' logo printed on a couple...
  4. shrop
    shrop El Jefe of Sleeving
    22 Jul 2011
    Dell AT101W on the way :D
  5. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    I've leveled up!
  6. Matticus
    Matticus ...
    23 Feb 2008
    Buy my Poker - http://forums.bit-tech.net/showthread.php?t=266975 :D
    I have found myself strangely falling a little bit in love with Red switches over the past few days. Since my Leopold is back on my desk at home and wearing HyperFuse, I am really enjoying typing on it. I think the fact it had OEM caps on it before made it feel much much worse than it was, though Keycool (slightly thick) PBT caps felt pretty good. I am also really getting on with Browns at work.
    This has made me not so bothered about trying Clears as I think stock they would feel a bit too heavy for me. Ergo clears seem like they would be my ideal switch, so I will just keep an eye/ear out for something.
  7. Yslen
    Yslen Lord of the Twenty-Seventh Circle
    3 Mar 2010
    I've decided that my new Poker is the keyboard for me, as it's lovely to use and far less clunky than I imagined now that I'm getting used to where the function key is :p
    As such I've cut down my Honeywell order pretty heavily; now just getting two 60% kits; grey and red mods with white alphas. Don't worry Margon your order is still in there!
    I'm going to sell my full size Cherry boards, as I've got a Model M for work etc. They'll be going up in the marketplace tomorrow when I get around to taking photos etc, but if anyone here is interested just PM me before I set that thread up and get in early.
    G80-3494, US ANSI, Cherry MX Reds, USB. Some light wear to a few of the legends, otherwise very good condition.
    £55 inc. postage
    G80-8113, UK ISO, Cherry MX Clears, PS/2. Vintage so well used but fully working, inc. POS, touchpad, programming functions. Lovely lasered PBT keycaps with non-stepped caps lock key. One of the five clips on the front underside has snapped but it's firmly held together by the other four.
    £50 inc. postage
  8. imersa
    imersa Parvum Princess
    9 Apr 2009
    Anyone got a nice cherry 1.75x shift going spare/ for sale?
  9. Gareth Halfacree
    4 Dec 2007
    Right, I've now written a couple of thousand words on the Filco. Latest impressions: high-pitched click still a bit annoying; I keep hitting the wrong keys, but that's to be expected after so many years using the bizarre IBM PC AT layout; the keyboard appears to not actually be flat, wobbling to the top-right with the feet in either position - 'fixed' with a folded-up bit of paper beneath the right-hand foot to fill in the strange gap; the keycap-on-finger feel is... Squeaky? I'm assuming it's because they're a different material to the Model F. Whatever, it's not the most pleasant sensation.
    I'm going to stick it out for a week, but so far it doesn't seem a patch on the Model F.
  10. Margo Baggins
    28 May 2010
    I think Model F has PBT caps where as the filco stock caps are thin ABS. The caps can make quite a lot of difference to the overall typing experience. I don't really like blues, I find them too light, I find all the light switches too light. Blacks, clears, tactile greys, greens, water axis (sapphires/blears) are all nicer to my fingers, but they are still not as heavy as BS.
    Now in life I really want this http://www.circuitspecialists.eu/so...-solderwerks-through-hole-desoldering-station I feel it would quite possibly be actually life changing.
  11. Matticus
    Matticus ...
    23 Feb 2008
    I think the stock Filco caps are widely regarded as a bit poor in comparison to aftermarket caps. Sounds like the texture on PBT caps would be better for you. Even just some plain white on black Signature Plastics caps have a bit of texture with a much nicer feel and profile.
    As for the wobbling, a lot of plate mounted boards can get a bit of a wobble especially full size boards. You can usually rectify it by grabbing both ends and gently twisting in the relevant direction to level things out. My KeyCool 87 had a little bit of a wobble which was fixed with a twist and has been fine since, as long as you aren't Lou Ferrigno you aren't going to do any damage.
  12. David
    7 Apr 2009
    I'm seriously considering buying a bunch of clears to replace the reds on my MK-85, even though it'll mean desoldering/resoldering the LEDs. How much of a pain is that? Is it just a case of two more tails per switch, or are there further complications?
  13. GeorgeK
    18 Sep 2010
    It's basically that really - 2 solder joints per switch and another 2 per led
  14. Margo Baggins
    28 May 2010
    Yeah, what george said - the LEDs are generally speaking a bit more of a pain as well as the hole pitch is smaller. But it's easily doable, have done quite a lot of back lit boards, unsoldering and soldering.
    Clears are quite cheap from mechanical keyboards - but for enough clears to do your board and quickly, Yslen's cherry G80-8113 would be your cheapest and fastest way. Is $55 for 110 clears on mechanicalkeyboards.com before shipping and potential taxes.
  15. LennyRhys
    LennyRhys Oink!
    16 May 2011
    Anybody interested in ALPs keyboards?
    Somebody has just listed what seems to be a large quantity of brand new Dell AT101W keyboards on ebay, available in both beige and black. Given that they are brand new, I've put in an offer for one of the black ones. If I like it, I'll get rid of my Quickfire MX Browns board.
    Anybody interested? At first I thought the price was kinda high, but all things considered, £20-25 for a brand new, good quality mechanical keyboard is really nothing to sniff at, and the seller is accepting offers below the BIN price.
    Boards are ANSI.
    Beige
    Black
  16. Gareth Halfacree
    4 Dec 2007
    Top tip - that's sorted it out a treat. Ta!
    Cheers for the advice regarding keycaps, everyone: as I said, I don't fancy spending a bunch of cash on this board if I'm only going to go back to the Model F, but if it's grown on me in the next week then I'll consider treating myself to some PBTs. Any recommended sets - UK layout?
  17. David
    7 Apr 2009
    Hmm, I hadn't thought about that - I was looking at a Skidata, but that 8113 is very nice, and I could re-use it with different switches.
    I'd imagine it'll be gone before I can buy it - I've had to cough up far too much money this month.
  18. Margo Baggins
    28 May 2010
    Skidata is LOTS more switches. I think there is about 180 odd on it, something like that. And tasty orange doubleshots :) (This guy hasn't ordered one that's for sure.....or something). The 8113 is really decent, really nice set of caps on it. skidata also would come from germany whereas 8113 is already in the country. so there is a few good avenues for sure :)
    PS. Your caps are actually in the post now!
    Good spot! Definitely haven't ordered a beige one....
  19. David
    7 Apr 2009
    German means QWERTZ though... which ruins things a bit for me.
    :hip:
  20. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    I've been tempted to buy a Skidata, but QWERTZ is a no go for me. I want ANSI international :)
