Peripherals Mechanical Keyboards
Discussion in 'Hardware' started by Raptor77, 27 Dec 2011.
  1. Gareth Halfacree
    4 Dec 2007
    It's brilliant - works like a charm. Smoked like a chimney when I first turned it on, uses an ungrounded plug and holds the tip at mains potential... Brilliant!
  2. GeorgeK
    18 Sep 2010
    Sounds like fun for all the family if you don't particularly like your family
  3. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    You are wrong! It had the potential to cause a rift, but, to this day she has never noticed it, so she doesn't realise it was an expensive purchase :)
    This is my current arsenal - its a fun thing to have lots of :)
  4. GeorgeK
    18 Sep 2010
    Man corner
    Edit: Glad to see you solder on your mouse mat too :thumb:
  5. jinq-sea
    15 Oct 2012
    Haha! I hope she doesn't read bit-tech...
  6. Margo Baggins
    28 May 2010
    no no I don't! i solder to the left of my mousemat, the stations all just live on the right of it, I solder normally just on my desk protector, unless I am doing air then I stick a heat proof mat down, as I've learnt that otherwise I melt the pcb's I am working on to my desk protector, which is no fun.
    No, but strangely she does a bit of GH
  7. Darkwisdom
    Darkwisdom Level 99 Retro Nerd
    27 Aug 2011
    I have a quick question for the electronically gifted.
    Is it possible to convert a Belkin N52te (basically the Razer Nostromo) to use mechanical switches. I'm pretty handy with electronics, wiring and soldering and don't mind don't the work for it. I just want to know if it's possible to do so; I don't really want to spend £120 on an Orbweaver. I've had this thing 5 years and I want to breathe some new life into it; I just don't like the feel of the keys now i'm used to Cherry MX switches.
  8. Margo Baggins
    28 May 2010
    They will have entirely different pcb's - due to how the domes work and how cherry mx works :( sadly.
    What you could consider - is building yourself a one handed ergodox? I think you can get pcb's and cases from mechanicalkeyboards.com - then you can just get a few passives and a teensy and make a one handed dox :) Probably for much less than an orbweaver. It's something I have been considering doing - then I remembered I don't really play any games, I just buy them instead.
  9. David
    7 Apr 2009
    Gratz to George.
    The mech board mafia, with it's very own triumvirate of moderators!
  10. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    It has been done. Looks like a lot of effort though.
  11. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    Damn this thread moves quick!
    If you mean the CM keyboard it's ISO, The ducky I was looking at is also ISO with green LEDs.
  12. GeorgeK
    18 Sep 2010
    You snooze you lose :lol:
    Fair enough - like I said, if I was in your position I'd always go for a separate keyboard and numpad. My reason is for desk space though - I still prefer to use a numpad right handed but I can move it back out of the way when I'm not using it.
  13. Darkwisdom
    27 Aug 2011
    Might be worth a go; i'd much prefer to spend little money on converting what I have rather than fork out what would probably be three, almost 4 times the cost to convert it on an orbweaver.
  14. IvanIvanovich
    31 Aug 2008
    You could get something like this to solve the use numpad and cursor block at once issue, though would need modding since it seems to use a parallel connector.
  15. 13eightyfour
    9 Sep 2003
    It's an interesting option but a lack of time and talent would mean I'd end up making a mess of it :D, I think I'll just get rid of this and go for the second option, TKL and numpad.
  16. JaccoW
    JaccoW Overspender on keyboards
    30 Apr 2009
    BingeCap Wax Seal Lion. :D
    Also, some blue leds and a led tester
  17. GeorgeK
    18 Sep 2010
    I'm not normally a fan of bingecaps but that looks awesome :)
  18. Shirty
    18 Apr 1982
    Nice to see some new faces in here :)
    George is right though - keep making noises until you get your answers or it'll get buried pretty quickly.
    You can solder whatever LEDs you like on a Ducky, Margon might need to tell you about resistors though. The only LED mod I've one is on this Cougar with a magical PCB that can drive anything under the sun.
  19. *Alex*
    *Alex* What's a Dremel?
    23 Mar 2008
    Sweet i want to do a rasta led light setup =P
    If Margo can point in the right direction that is :thumb:
    Cheers
  20. fuus
    fuus Rocking All Year Christmas
    4 Dec 2010
    Sorry, wat. Surely the mains goes through your PCB?
