HTPC Media Box
Discussion in 'Hardware' started by crazydeep74, 12 Mar 2006.
  1. crazydeep74
    crazydeep74 What's a Dremel?
    25 Jul 2005
    Well as you may have read im getting a new room next month. I want to make a nice entertainment system and that would include getting a new PVR. Here are the specs as Ive figured out so far.
    Mercury PVCLE266M-Lv3.0 & VIA C3 Samual 2 $54.99 after rebate
    Kingston 512MB CL2.5 PC2100 DDR 266MHz Memory $44.99
    Seagate / 40GB / 7200 / 2MB / ATA-100 / EIDIE / OEM / Hard Drive $49.99
    ASUS 16X DVD Drive E616A $22.99
    I need to choose a tuner, What do you recommend? Something VERY easy to setup (I will use windows xp pro sp2)
    Also whaty do you recommend for a free media center program?
    I also need a video card, problem is the TV only supports, RCA Composite (Red, yellow, white) and umm that NPR, CPR, P or wtvr the other RCA looking connectors and S-Video. What would offer the best video?
    I need it too look good on a 32Inch TV, all my other stuff will be running through it (IE. DVD, VCR's etc.).
  2. crazydeep74
    25 Jul 2005
    I have a Sabrent SBT Tuner, and a ATI AIW I can use for tv out (Its only 4mb though). Then I wouldnt have to use a Media program. This would have to run thought a right angle PCI adapter (One that goes in one socket but has two ports on it.
  3. herbs
    herbs Nobody but us chickens
    7 May 2001
    With a C3 processor if you want to do recordings you will need hardware encoder tv card something like the pvr 150.
  4. crazydeep74
    25 Jul 2005
    The C3 wont do hardware encoding?, Well then what about a CA64 TN with a Pentium 3?
  5. herbs
    7 May 2001
    If I knew what a CA64 TN was then I might be able to answer your question.
  6. crazydeep74
    25 Jul 2005
    Its a DFI motherboard model. Ive settled on using a Motherboard I have lying around with the intel 815e chipset, and a 800MHz Pentium 3 360. Here are the specs atm.
    Sabrent SBT TVFM
    ATI All In Wonder 4MB (for the time being)
    40GB Harddrive space
    DVD-Rom Drive
    512MB Ram
  7. herbs
    7 May 2001
    Even a p3 800mhz isn't going to cut it at full resolution recording in mpeg2 or mpeg4. Which means you need a hardware encoder card ala pvr 150.
