HTPC Media Centre PC: XP vs Ubuntu
Discussion in 'Hardware' started by modgodtanvir, 31 Aug 2008.
  1. modgodtanvir
    modgodtanvir Prepare - for Mortal Bumbat!
    28 May 2007
    I have an old Dell lying around and I thought it would be nice to make this the beginning of a little wireless portal of entertainment...
    The specs are:
    800MHz PIII Processor
    512MB of Ram
    Onboard Intel Graphics
    Soundblaster (can't remember which one :p) 7.1 Sound Card
    14GB HDD + 160 Storage HDD
    I was just wondering if I would be better off with the universal and all compatible Windows XP (which is already installed) or if it would be better to squeeze more out of the system with a linux install...
    I'm guessing XP, but I can't be too sure so I thought I'd get a second opinion on it.
    Thanks in advance for your time,
    MGT :thumb:
    EDIT: Also, I was wondering what would be the best way to get a remote control on the PC? I think there is a version of XP called 'Media Center edition' which uses a remote... is there a way of getting just that remote control on a normal XP Home install?
  2. mirciu
    mirciu New Member
    7 Jan 2007
    first of all, i my opinion that system is a little bit outdatet for video playback in the form of hd. standart def would work just about fine. for the software aspect i would choose linux mce. it's based on ubuntu so you shouldn't have any issues. i found the eyecandy acceptable and the overall experience quite good. for more info visit www.linuxmce.com
  3. modgodtanvir
    28 May 2007
    The hardware is most definitely outdated :p I'll struggle to play DVDs with this thing, let alone High Def... but I'd like to use this because it was my first ever computer and don't want to throw it away (just yet :p)...
    Thanks for the link to LinuxMCE. I've never come across this before and it looks interesting...
    In the mean time, I decided I might take a bit of a shortcut and get one of these:
    It basically turns you system into a media centre. The VFD will control the sound and video system, with many programmable functions, and can even access your inbox and weather forecasts... so that solves the remote problem. Has anybody here used anything by Soundgraph before?
    Also, is there somewhere on the net for Media Centre building enthusiasts? I'd quite like to see what people are doing these days, and check out the current trends. Keep an eye open in the project logs :dremel: I'll get to work soon...
    :thumb: MGT
  4. Guest-16
    Guest-16 Guest
    XBMC on Ubuntu is fantastic for your kind of hardware but it obviously features limited remote support, or if you want to try something slightly different but not as good - Boxee is in Alpha and based on XBMC.
    The iMon software.. isn't hugely great to be honest. Well, if it's the same one that was used in the Zalman HTPC case we reviewed a while back.
  5. Elv13
    Elv13 New Member
    26 Apr 2006
  6. Woodstock
    Woodstock So Say We All
    10 Sep 2006
    just about any remote will work with linux, using the LIRC program
  7. modgodtanvir
    28 May 2007
    Dude, thanks for an awesome collection of links :thumb: I'll have to try each one of those in turn since they all look pretty good. :D I've just installed Media Portal and it looks pretty amazing...
    Really? I've seen iMon stuff used in other HTPC's as well... (Antec Fusion?) and tbh, it looks more like eye candy then anything else... I'll have a look for those Crystalfontz style VFD's as well...
    Remote problem solved :thumb: And if its safe to assume the Windows XP MCE remote is compatible, I'd say we're looking at a winner :clap:
    Thanks for the help so far dudes :D
    I'll phone up some local metal companies tomorrow for some aluminium (Keeping away from the plywood :p). Has anyone here ever bought anything from Hindleys? It looks pretty awesome...
    Cheers,
    MGT
  8. Cinnander
    Cinnander New Member
    19 Apr 2007
    Before you start can I recommend you check that the wireless card you intend to use isn't going to be a pain in the arse - some are, some aren't. Mostly the ones that need firmware in the drivers which is unavailable from the manus are the ones that suck. I guess just google "Linux install <name of card>" and see how many forum threads you find :p Broadcom are especially bad in my experience.
    OTOH you might find it works fine with just a LiveCD running (I had an Edimax El-cheapo-crappo which did exactly this) :eek:
  9. Guest-16
    Guest-16 Guest
    Oh win!
    Now I've got to find my Vista MCE remote in the list.
  10. Woodstock
    10 Sep 2006
    lol, was going to use a multi-function remote i picked up cheap, but i sorta knocked it out the window and didnt relise into the next morning, had 10mm of rain that night
  11. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    We use Elisa Media center on Ubuntu in our Unions clubroom. Works great with a WiiMote as input :D You ca just flick thru everything with a hand movement
  12. Guest-16
    Guest-16 Guest
    THIS sounds awesome.
    Video please.
  13. steveo_mcg
    steveo_mcg New Member
    26 May 2005
    If its just for (sd) video playback i can't recommend geexbox highly enough, i've been using it for years on kit much about the same as yours, brilliant even the wife can work it. LIRC can be a bit tricky sometimes, although i've not looked at it in ages so it may have improved, i just use an ati remote which is supported by default.
  14. AJB2K3
    AJB2K3 New Member
    12 Dec 2005
    Just had a play with XBMC on my 1.2ghz umbum lappy and I impressed.
