Build Advice Media/gaming build
Discussion in 'Hardware' started by penryn 2 hertz, 5 Apr 2011.
  1. penryn 2 hertz
    penryn 2 hertz I'm not a science fiction writer...
    10 Jun 2010
    this is the build
    1. Phenom iix3 720be 2.8ghz have got
    1. OCZ DDR3 PC3-10666 1333MHz Platinum Edition Low Voltage 4GB Dual Channel have got
    1. MSI 880GMA-E45
    1. HD 5850 superoverclock vapour x 1gb
    1. ocz vertex2e 60gb ssd have got
    1. 2x500gb spinpoint f3 sata in raid 0 files have got
    1. ocz modxtream 600w modular psu have got
    1. gelid tranquillo cpu cooler have got
    have no clue what case to go with but thats the build peeps ???
  2. penryn 2 hertz
    10 Jun 2010
    any opinions???
  3. Deders
    Deders Modder
    14 Nov 2010
    Can you still buy OCZ ram? you may have warranty issues as they have left the ram market, worth checking if they still honour warranties, their RMA service is great.
    Also, why 2x 500GB F3's and not 2x 1TB F3's?
    Everything else looks sweet.
  4. Guest-16
    Guest-16 Guest
    Didn't even know they made 720 Black Editions any more tbh!
    What's your budget?
  5. penryn 2 hertz
    10 Jun 2010
    got one second hand for £40
  6. Guest-16
    Guest-16 Guest
    Very nice!
    You want to make sure the board you buy has an unlocking facility then :)
  7. Marine-RX179
    Marine-RX179 What's a Dremel?
    24 May 2010
    If you don't want to spend a fortune on the case, the CoolerMaster Elite 430 is a good case for the price (around £30). Otherwise a little higher in price such as CoolerMaster 690 II Lite or Advanced are good options as well.
  8. adam_bagpuss
    24 Apr 2009
    budget ?
