Build Advice Media PC suggestions
Discussion in 'Hardware' started by Noggin2k1, 29 Jun 2011.
  1. Noggin2k1
    Noggin2k1 What's a Dremel?
    30 Apr 2004
    Afternoon guy's,
    First and foremost, let me just run through what I'm looking at using this PC for:
    It's going to be my main and only PC, used for simple things;
    -Browsing the internet
    -Listening to music
    -Playing a smidge of Football Manager
    -Watching DVD/TV
    What I want out of the system is as follows:
    -As quiet as possible
    -Looks good
    -Small as possible!!
    -Does the job it needs to...
    Budget: Give or take £500 for the base unit.
    An area I need a bit of advice on... In my room (where it'll be based), I don't have a TV aerial, just a Sky HD point to the dish - not paying for as it's not getting the use. What's going to be the easiest way to connect this up to a PC for freeview, hopefully HD channels? I'd like it to be as internal as possible (no USB bits knocking around if possible, PCI-E x1 card would be preference)
    My idea's so far would be the following:
    Base
    Replace the 220W PSU (it's known to not do the job and be noisy) for:
    PSU
    And then wang in a half decent low profile graphics card, with low power usage & heat (suggestions), a TV tuner card, a CPU cooler that's quiet and half decent (the case only has 1x80mm intake fan).
    Intruiged to know how you guys would do it.. :)
    Cheers!
  2. Modsbywoz
    Modsbywoz Multimodder
    14 Oct 2009
    Can you use freeview and sky thought the same dish at the same time?
  3. Noggin2k1
    30 Apr 2004
    Not too sure but don't think that's an issue - the Sky dish isn't being used at all at present.
  4. Jaybles
    Jaybles What's a Dremel?
    12 Feb 2011
    + a cheap aerial or grab a satellite tuner instead and point it at the freesat satellite. you cant get freeview via satellite it has to be aerial.
    on a side note if you wanted freeview hd you would need a dvb-t2 tuner such as this.
    Edit: If you have more than 20 posts you can get free delivery at Scan. If you are a student you can get discounted or free copies of Windows 7.
  5. bnicholls195
    bnicholls195 What's a Dremel?
    15 Mar 2011
    What about a freesat tuner? You can get four HD channels that way. The channel listing is not the quite the same but its near enough.
  6. chewbaccas_nan
    chewbaccas_nan Minimodder
    27 Jun 2011
    Would it pointless in buying a CPU cooler if you're not really overclocking? You could just keep it stock and put the money on something else?
  7. Jaybles
    12 Feb 2011
    OP said quiet and i think an aftermarket would aid this.
