Windows Media Player Help
Discussion in 'Tech Support' started by chrispy61, 14 Nov 2010.
  1. chrispy61
    chrispy61 What's a Dremel?
    29 Jan 2010
    Ive got an issue which is quite annoying. When ever im watching stuff through media player after about 20 mins the screen goes black and i loose the sound almost like it goes to sleep but ive changed the settings in power options so it doesent go to sleep. And also ive disabled the screen saver. Any ideas??
  2. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    Might be a power saving setting in the bios, using onboard graphics I take it?
  3. chrispy61
    29 Jan 2010
    no onboard grafics, i5 & P55 mobo mate? Do you think it could be in BIOS settings sumwere?
  4. SuicideNeil
    17 Aug 2009
    If you have / can download the manual its certainly worth having a read to check. Reason I asked about the graphics is because if you're running a card, it may have its own power settings that are causing it to turn off after x minutes, vs the mobo / OS being responsible..
    I am only thinking out loud though, never had this issue myself as I do only use onboard graphics ( not a gaming/ graphics pc, just basic work/porn station :lol: )
  5. dancingbear84
    dancingbear84 error 404
    16 Oct 2010
    Is it a lappy or a monitor, Is there a powersave mode on that?
  6. chrispy61
    29 Jan 2010
    Thanks for the replys, shudda sayed at the start. The reason ive found this problem is because i run an HDMI cable from my GPU to my TV and watch movies thru that so dont think its monitor related as i normaly have the monitor switched off. Il have a look at the other options tho.
  7. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    there is power saving options in the bios but I doubt that's it.. there's a icon called power options in the control panel, should set it up
  8. Reitau
    Reitau WizD Rawks
    21 Nov 2010
    When you say media player do you mean media centre? as that has its own settings screen for power saving and will shut off regardless of settings in control panel.
