Hey guys, I have tablet/laptop/smartphone etc and I was fooling around with streaming and i liked the idea of having a small tiny computer low power (with windows?) running 24/7 as essentially a harddrive with wifi access. any ideas what I should do? build a minipc? or is there other alternatives, im sure there must be but i cant figure out the right keywords to google lol. at the moment I have my workstation sharing a folder which ive stuck films etc in and Im able to stream fine but I dont want to leave my workstation on 24/7. thanks guys!
A HP Micro Server would be ideal for this I reckon. I wouldn't stream via WiFi as I've had stuttering issues in the past but if it works for you, go for it.
Sounds like you're looking to get a basic NAS. There are quite a lot of choices for ready to go out of the box, repurposing basic hardware like thin clients on the cheap to full blown home server builds. It depends a lot on if you want it to be able to do other tasks, if you want any options for upgradability and budget. Streaming wifi, well it is usually just a poorer experience... especially with HD media as it can easily get choppy due to the bandwidth required that wifi can easily fail to deliver. It's much better to have NAS on wired network if it is at all possible.
Okay that sounds like an idea, I'll look into them. Function wise I literally just want something to stream movies/pictures/music from. I want to be able to remove the hdd, easily move files onto it and stream to like 2/3 devices at 1080 (or higher if possible) at the same time? but I dont want to spend like 200quid on it lol. I also have a secondary micro atx pc I could use for this but I dont want that running as it will most likely require more power = higher bills
Depends, what is your matx set up... you might always be able to underclock it and use lower watt PSU to make it more efficient. Otherwise I would hit ebay for a good deal on a basic Atom or Via C7 motherboard. At least in the US those are often easy to find for super cheap price.
