MediaPC Black
Discussion in 'Project Logs' started by Swampytoadstool, 15 Nov 2005.
  1. Swampytoadstool
    Swampytoadstool What's a Dremel?
    14 Nov 2005
  2. Swampytoadstool
    14 Nov 2005
    I decided to make another MediaPC a while ago..so i got the required parts. (galvanized sheet metal, angle aluminum, and screws.) Anyway, i had all the other parts i needed already, except for a small psu and a tv tuner, got the psu from newegg, and i'm waiting till xmas to get the tv tuner :worried: lol.
    Ok, so i made the sheet that the motherboard mounts to first, and all the angle aluminum sides that go with it.
    Picture time: Motherboard mounted to the bottom plate + bottom angle aluminum trim.
    Next i started making the front/side panels for the case, and the trim that connects them together.
    More pictures:
    then i bolted all that together, and made the back panel too.
    The hardest parts of this creation was definately the top panel, because i was including a plexi glass center from a window mod kit...and of course it was hinged as well. heres some pics of it coming together.
    took the film off the plexi.... :hip: :eyebrow:
    Getting parts ready for painting, and the trim ready for polishing :D :worried:
    Back from paint :D
    Assembling the lid and case
    hehehe i had to take a break for a while when i got to this point b\c it looked so great compared to other things i've made :dremel:
    i'll wait to show you the finished product.... :hip: :rock: the suspense is killing you isn't it?
    project log discussion :::: http://forums.bit-tech.net/showthread.php?p=1109412#post1109412 :::: Leave comments/ suggestions please :D
  3. Warrior_Rocker
    Warrior_Rocker Holder of the sacred iron
    26 Jun 2005
    As far as MediaPC's go, this is one to follow, very impressed by your work so far, as the owner of the original of its design i give you an A+ :rock:
    cant wait to see it finished, keep on :dremel: 'n
  4. Hellboy787
    Hellboy787 What's a Dremel?
    3 Nov 2005
    Swampytoadstool... It looks great and I hope you finish it soon so we can see the final result......I just might start my own media centre... thanks for the inspiration..
  5. DeLorean5000
    DeLorean5000 What's a Dremel?
    3 May 2003
    Looking good dude, i cant wait to come see it again. This kid has put in alot of work to this thing, it looks awesome in real life. :D Have you tried getting the spots off the plexi yet? And i thought the hardest part of it was me not stealing it :hehe:
  6. Swampytoadstool
    14 Nov 2005
    Thanks guys, i'll update again soon, waiting for more parts(lol)
    questions/comments/suggestions? anyone?
  7. phuzz
    phuzz This is a title
    28 May 2004
    You can pick up cans of lable remover from maplin's btw. I used to use it at work, and it cleans that sticky gunk off like anything, well handy for that PSU of yours. (And then you can use it to clean and polish just about anything)
  8. Swampytoadstool
    14 Nov 2005
    anyone have suggestions on where i should put fans? i was thinking about one in the plexi but idk...
  9. DeLorean5000
    3 May 2003
    I think the sides would be better, the plexi is a pain to cut and may crack... it already did in one spot right?
  10. Swampytoadstool
    14 Nov 2005
    Yeah near the front edge, it's hidden by the trim though.
