Electronics meet my MOOLED
Discussion in 'Modding' started by coorz, 30 Dec 2005.
  1. coorz
    coorz Miffed
    25 Apr 2003
    So what's a MOOLED? Basically a Matrix Orbital (MO) MX232 USB LCD with an OLED make-over, ok i know you can buy these now, but hey where's the fun!
    Actually i stumbled upon it by accident as i noticed the OLED module being exact the same size and pin layout as the MO LCD.
    pix!
    In the very beginning there was..
    The OLED module, first wired and tested to be really HD44780 compliant. It is.
    Side by side
    Separated! Notice the OLED module being very thin.
    Equipment, my AOYUE hot-air de/solderstation and that heated tin-sucker(?) what a brilliant invention!
    OLED module joined to the USB backpack
    And yes it works! Quite nice i must say this OLED stuff, super viewing angle. Green on a deep black background.
    How's that for a little fun :wink:
  2. doryakov
    doryakov What's a Dremel?
    8 Aug 2005
    where did you buy it?
  3. coorz
    coorz Miffed
    25 Apr 2003
    ebay
  4. Wolfe
    Wolfe What's a Dremel?
    7 Sep 2003
  5. Hazer
    Hazer In time,you too will be relixalated
    14 Apr 2003
    Sweet.
  6. Turbokeu
    Turbokeu Minimodder
    30 Jul 2002
    Great find Coorz!
    They are beautiful!
    Prettig Nieuwjaar!
    CD :)
  7. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    nice!
    i want one.
    i was just looking for some of those OLED's. I found some PLED (basicly the same, i think). They are actually cheaper than LCD's. :confused:
    i also found a graphic PLED. Not too expensive either.
  8. nleahcim
    nleahcim What's a Dremel?
    22 Apr 2003
    Damn - at only ~$30 I might have to pick up one of those buggers. How is the current consumption? And how is the visibility in sunlight?
  9. coorz
    coorz Miffed
    25 Apr 2003
    Current consumption is in the specsheet which is included. Visibility i must say is even better than VFD due to the stark green/black contrast.
    Viewing angle is ofcourse a non-issue.
    HAPPY NEW YEAR BTW!!!
  10. nleahcim
    22 Apr 2003
    included with what? I couldn't find it on the auction page...
  11. coorz
    coorz Miffed
    25 Apr 2003
    There's a better datasheet included when you buy them.
  12. nleahcim
    22 Apr 2003
    Or you could just take a quarter second and check for me...
  13. Smilodon
    25 Mar 2003
    the ones i found was 100mA max, IIRC.
  14. coorz
    coorz Miffed
    25 Apr 2003
    Hehe yes ofcoorz i could do that IF the display was here at home :)
    Smilodon, which graphic PLEDS have you found? I've seen a couple which are very usable, though quite expensive 45 euro and up.
  15. Smilodon
    25 Mar 2003
  16. coorz
    coorz Miffed
    25 Apr 2003
    I've seen that Bolymin OLED before, though it claims KS0108 compatability it isn't as it only has one CS pin.
    This one (OLED>GRAFIK) looks to be really KS0108 compatible, and cheaper than Elfa!
    Ofcourse this is assuming you want to use these displays with common LCD apps, otherwise any OLED will do if you can write your own routines (i can't :sigh: ).
  17. ConKbot of Doom
    ConKbot of Doom What's a Dremel?
    2 Jul 2003
    Thats sharp looking. I'll defintiely have to check that out.
  18. coorz
    coorz Miffed
    25 Apr 2003
  19. Turbokeu
    Turbokeu Minimodder
    30 Jul 2002
    Hi coorz!
    I managed to win one of those OLED displays from eBay for $15.50 + $7.50 shipping.
    Now waiting for the display to arrive...
    Thanks for the links to the eBay auctions.
    Chris :)
  20. Firehed
    15 Feb 2004
    So I've gotta ask, can you only get that USB converting board attached to a MO LCD display or can you buy them independantly?
    Of course, I really should just hook up my new VFD. Haven't gotten a chance yet. Damn college essays.
