Electronics meet my MOOLED
Discussion in 'Modding' started by coorz, 30 Dec 2005.
  1. coorz
    coorz Miffed
    25 Apr 2003
    Hey Turbo you'll like it a lot, just as cool as VFD and nixies :)
    Firehed; MO doesn't sell the USB backpacks, there are other USB backpacks for HD44780 displays on the market, though i have no idea how (good) their software support is.
  2. Henry
    Henry Matrix Orbital
    13 Jul 2001
    coorz made a MX6 ;) heh...
    we also do sell the parallel version, and a really nice economy serial version of the PLED as well
    Parallel Version 2x16 $23.72 and 2x20 $29.55
    http://www.matrixorbital.com/index.php?cName=lcd-mop-character-pleds
    Economy Serial: 2x16 $34.95 and 2x20 $49.95
    http://www.matrixorbital.com/index.php?cName=lcd-mos-character-pleds
    USB and High End Serial: 2x16 $62.95 and 2x20 $76.95/$79.95
    http://www.matrixorbital.com/index.php?cName=lcd-character-pleds
    They come with a year warantty from us and all the tech support and all the othe jazz when dealing with us ;)
    I love the PLEDs, they have about a 10mA power draw, 160 degree viewing angle... pretty much all the benifits of a VFD, but waaaay cheaper and less power draw... but no other colour then the yellow green ATM...
    And we could sell just the USB interface board... if you want a price let me know... we normally do not sell them because of support issues...
  3. coorz
    coorz Miffed
    25 Apr 2003
    Oh shameless.... :hehe:
    Good move; selling USB backpacks with LCDC to back it up. I'd like to know the price.
  4. Henry
    13 Jul 2001
    It's not a normal thing, just a special thing really... we wil be putting out a USB interface board soon...
  5. Wolfe
    Wolfe What's a Dremel?
    7 Sep 2003
    I am interested in pricing as well.
  6. nleahcim
    nleahcim What's a Dremel?
    22 Apr 2003
    80mw? Sweet - and thanks for the datasheet link. I've been looking for a display for an embedded board I'm working on and that might be a good fit. Too bad it's 5V though (and not 3.3). Can't win them all I suppose.
  7. Turbokeu
    Turbokeu Minimodder
    30 Jul 2002
    Hello coorz,
    My OLED arrived from China after only 4 days.
    I suppose I just need a 10k trimpot between GND and +5V with wiper to VBT (pin3) for the contrast setting?
    CD :)
  8. coorz
    coorz Miffed
    25 Apr 2003
    Correct, however i omitted the pot and just wired pin 3 to +5v for max contrast, as i found out that the pot is useless as there are no contrast issues with OLED :)
    It only looks good at max contrast.
  9. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    Pin 3 simply controls the brightness of the display with OLED displays.
  10. coorz
    coorz Miffed
    25 Apr 2003
    You are correct, we mean brightness. A smaller pot would be better if one must have control, the 10K is too big.
  11. Henry
    13 Jul 2001
    Lets say $34.95...
  12. crazydeep74
    crazydeep74 What's a Dremel?
    25 Jul 2005
    Really cool mod....
  13. user0001
    user0001 What's a Dremel?
    8 Sep 2004
    Nooooooo! :sigh: I'd love to see something like those Electroluminescent displays coorz has... :D
  14. Henry
    13 Jul 2001
    The problem is, the blue and red PLED displays, last 4 to 6 thousand hours only... compared to a 100,000 hours of a LCD...
  15. zachjowi
    zachjowi What's a Dremel?
    15 Jan 2005
  16. ChriX
    ChriX ^
    30 Aug 2001
    Coorz/Henry: may seem a bit of an odd question, but as you may remember I have one half of a MX2 mounted to the front of my CD-rom drive, with the USB backpack relocated elsewhere. The problem is that the years of that screen and the thick aluminium blanking plate on the front of the tray has disagreed with the CD-rom drive, so I was wondering if the PLED modules are any lighter? The tray works fine without the weight on it, so I need some way to cut the weight down a bit.
    Here's what i'm on about http://lcdgallery.net/?f=view&lcdid=241
  17. coorz
    coorz Miffed
    25 Apr 2003
    Yes the OLED modules are much lighter, and also 2 or 3 times thinner.
    Well at least mine's are.
  18. Turbokeu
    Turbokeu Minimodder
    30 Jul 2002
    @coorz:
    I had finally some time to play with this OLED display but I have some issues:
    I get garbage on the display after some seconds when connected to a PIC microcontroller circuit. This circuit works perfect with any other HD44780-compatible LCD, and also with Noritake LCD-compatible VFD's.
    The PIC routines do check the busy bit of the LCD, therefore it shouldn't be a timing problem.
    I made a quick PCB layout to connect the OLED to my parallel port with LCDsmartie. Guess what: I have still that garbage on the OLED (some screens are okay, other screens start okay but get garbled)...
    What are your experiences with the 'Surestore' OLED module?
    CD :)
  19. coorz
    coorz Miffed
    25 Apr 2003
    I've had no issues with the OLED whatsoever on both the one wired to LPT and on the MO. Maybe grounding issues?
    I did get pointed out to the fact that the backlight should be run at max 3V to prolong it's life, instead of what i did straight to +5 for max brightness.
