Modding Mega Big Server Tower
Discussion in 'Modding' started by KillerBee, 15 Oct 2001.
  1. KillerBee
    KillerBee What's a Dremel?
    15 Oct 2001
    check this out :)
  2. Fatboy
    Fatboy Bored
    8 Oct 2001
    Now that is just insane! it would fall over though, make it wider.
  3. Phil
    Phil What's a Dremel?
    19 Jul 2001
    so so flawed...
    1. It's a hazard to passing aircraft. You'd have to put warning lights up the side of it. Terrorist magnet.
    2. even a 3 foot cable won't reach half way up !
    3. So much wasted space behind the drive bays...
    4. already been said....it will fall over
  4. Cheese
    Cheese Doc
    6 Oct 2001
    How do you know the space is wasted eh? It might have double sided drive bays or or a giraffe might life in their or something. Yeah.
    r. :D
  5. Fatboy
    Fatboy Bored
    8 Oct 2001
    If the MoBo was in the middle of the case some problems would be fixed like cable lengths. Add Some ultra wide feet. And finally add 20+ 120mm fans to get 1cubic mile of air per minute! that would be insane.
  6. Cheese
    Cheese Doc
    6 Oct 2001
    No no the mobo should be at the bottom... it would have to be a scsi set up so the cables would route from one drive to the next and length wouldn't be a problem :) You'd only have to worry about the power issue, and I'm sure we've all seen how long the enermax psu cables are :D
    r.
  7. Cheese
    Cheese Doc
    6 Oct 2001
    Oh. But wait. Is that a floppy bay at the top? ok then the mobo needs to be at the top and and a very long kettle lead is required :D
    r.
  8. DaveH
    DaveH What's a Dremel?
    11 Jun 2001
    Reaching the power button would be quite hard as well
    You can also have a massive window in the side of the case:rofl: :cool: :rofl:
  9. Fatboy
    Fatboy Bored
    8 Oct 2001
    Just lighting up the damn window would take bloody ages :rofl:
  10. KillerBee
    15 Oct 2001
    nice case ha. is photoshop but i like my photoshop :) because its so funny there could be place for serval mobo's :) and the ide cables of 20meters long :) there are some standard lights above the case for the planes. it also stand next to my house so ik kan press the power button out of my window :)
    next case comming soon :)
    KillerBee Out
  11. RTT
    RTT #parp
    12 Mar 2001
    specially for me :D
    :rofl:
  12. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    at least you could fit a bong in it ;)
  13. Guest-16
    Guest-16 Guest
    LOL!!! :rofl: :rofl:
    You scroll down... down... (start laughing) down... (laugh harder) down... DOWN!! (Fall off chair) and finally reach the base :D:D
    hehehe
  14. Cheese
    Cheese Doc
    6 Oct 2001
    Heh ROFL! :D
    r.
  15. :: kna ::
    :: kna :: POCOYO! Moderator
    15 Mar 2001
    You can't reach the power button on a normal PC RTT :rofl:
  16. PC4LIFE
    PC4LIFE What's a Dremel?
    11 Oct 2001
    Why only one floppy drive. If it is so big u could have like 10 or 20.
  17. Phil
    19 Jul 2001
    even if you filled all the pci slots up with floppy controllers you couldn't have more than 12
  18. KillerBee
    15 Oct 2001
    because its a photoshop of a Aopen hx08 case.
  19. Phil
    19 Jul 2001
    nooo, really ? and i thought it was real :D
  20. Fatboy
    Fatboy Bored
    8 Oct 2001
    I have seen a case on VH which has 10 5.25 bays , twas like a normal tower it wernt wide
