Scratch Build – In Progress Megablaster 2010 work log (diy ghettoblaster)
Discussion in 'Project Logs' started by drakmin, 14 Mar 2010.
  1. drakmin
    drakmin I don't use Dremel.
    20 May 2006
    This is a work log of my fourth ghettoblaster project. Here's the two first models I've built (2007) to give you the idea of my work:
    For the year 2010 my goal is to make lighter yet louder model. First dark grey model weights 11kg. I plan to cut the weight 25% using LiPo battery. Here is the 3d plan for my 4th design.
    I will build it using plywood which will be covered with 1mm black acryl. I searched for speaker part for a month. I was after high efficiency drivers to get out as many db per watt as possible. I found a DIY kit of a PA speaker which converts one watt of amplifier power to 94db of sound. This PA kit has horn tweeter so I had to alter the 3d plan a bit. Here's the final plan with horn tweeter in place:
    My plan consists of 2x100w class-d amp, 5,8Ah LiPo battery and Visaton MB 208/H speaker kit. Here's some parts as they arrived to me:
    First test of the amplifier:
    Cardboard model to see that the drivers fit:
    Time to start building. I chose 9mm plywood. My first blaster had 12mm plywood walls and it was overly sturdy and added unnecessary weight.
    Battery compartment:
    Bracing:
    Starts to look like a ghettoblaster:
    And first sound test:
    So this is where I am at the moment. Next I will build the plywood base for the carrying handle. After that the next step is to measure everything and draw the acryl cover parts in cad.
    Here's my modding gallery: http://allthemods.com/userinfo.php?userid=25
    Thanks for reading!
  2. Unicorn
    25 Jul 2006
    Welcome to the forum, and nice job on that so far! But this is in the wrong forum, you want "project logs" under "modding".
    I'm sure a mod can move this.
  3. drakmin
    20 May 2006
    Thanks! Project log rules said project logs can be only about pc mods. Im confused :]
  4. Unicorn
    25 Jul 2006
    Oops, that should be modding then. Sorry!
  5. Jipa
    5 Feb 2004
  6. drakmin
    20 May 2006
    Thanks Jouni. Here's fancy links to my previous projects, thanks for watching!
  7. knuck
    knuck Hate your face
    25 Jan 2002
    impressive :D
    I especially like the logiwood project :)
  8. drakmin
    20 May 2006
    Thank you! Here's a quick plan I made for the carrying leash:
  9. drakmin
    20 May 2006
    I think I'll go with the polished look:
  10. Nexxo
    23 Oct 2001
    This seriously tasty project is moved to the exalted heights of the Project Logs, where it belongs. :thumb:
  11. Cheapskate
    13 May 2007
    Nexxo has spoken!:lol: Welcome to Bit-Tech, and remember to fill in all the juicy details on the electronics.;)
  12. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    nice work....will there be an LCD screen in the middle?
  13. drakmin
    20 May 2006
    Thanks a lot Nexxo and Cheapskate!
    Here's the electronics simplified:
    I chose litium polymer battery since it's light and small. LiPo batteries are more expensive and dangerous than "normal" acid batteries. My 5,8Ah model cost about 80 dollars. Blaster need battery monitor since lipo batteries cant be drained too empty, they will be damaged. I bough 2 dollar lipo monitor from Hobbyking. It gives alarm sound when battery voltage drops too low.
    When building portable audio devices it's important to choose amplifier with high efficiency. Class-d amps are good choice, I found my model over ebay. It gives 2x100w into 4ohm load when fed with 36V voltage. My battery has 18,5V voltage so I will get "only" 2x40W power from the amp.
    Even more importand aspect is the sensitivity of the speakers connected to the amp. Sensivity tells how much sound speakers produces with 1 watt power. I chose Visaton diy kit which has 2x 8" bass drivers and a horn tweeter. These speakers will produce 94db of sound with 1 watt power. (pretty loud) I calculated with 40W power I will get about 120db of sound!
  14. drakmin
    20 May 2006
    HandMadeAndroid: Nope, no lcd's.
    My design philosophy is to keep the electronics as simple as possible. The K.I.T.T scanner is great exception here :D Atleast on my scale. Led scanner has no other function that to look cool! It's more like a pseudo cool addition.
    The center hole is reserved for the horn tweeter. Here's a pic of the drivers while I tested the crossover:
    And here's a bonus photo of me in my fancy working environment. Modders spring fashion 2010:
  15. drakmin
    20 May 2006
    I almost forgot. Here's first soundtest. Shot with my cellphone but I'll do better videos later. Not sure how to forward the 110db sound to video's watcher. In real life it plays really really loud!
  16. HaoKi
    HaoKi Lleno de anguilas!
    10 Oct 2003
    Ah... good to see Drakmin has wandered way over here onto the Bit-Tech forums ;) The blaster better be finished before the next LAN... :D
  17. shomann
    shomann Minimodder
    5 Sep 2003
    This is seriously awesome.
    Please forgive my ignorance but is there a reason to build the frame out of wood? I ask because you mentioned weight as a concern and I would think a fiberglass base would solve that issue nicely.
    Does it have to do with tonal quality?
  18. Neji
    Neji What's a Dremel?
    3 Jan 2006
    This is excellent. Mod on.
  19. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    Tonal Quality, yes. Same reason acoustic guitars are made with wood and not metal/fiberglass
  20. drakmin
    20 May 2006
    shomann:
    First of all plywood is cheap and really easy to work with. Also thin plywood is pretty light. I think my whole box weights 3kg since I routed unnecessary areas thinner. Sound _quality_ isn't first priority in ghettoblaster so glassfiber would be fine but harder to work with. Glassfiber box with some plywood braces inside would be pretty optimal in my opinion. Weight and sound pressure come before sound quality for me with blasters :D Wall thickness in this box vary from 6mm to 12mm. My first model was thicker and it turned out to be unnecessary. As I've already tested this box it doesn't rattle or do anything unwanted :D
