Scratch Build – In Progress MegaDeblow - Desk Build **COMPLETE**
Discussion in 'Project Logs' started by Deblow, 30 Jan 2014.
  1. Deblow
    Deblow Minimodder
    12 Dec 2013
    Finally my 12v push on/off switches have arrived
    Will be used for the UV/LED lighting.
  2. Deblow
    Deblow Minimodder
    12 Dec 2013
    Stared working on the pump & res base,
    a total remake but just a bit bigger than the 1st one i made and now has a hole for the pump instead of hiding the pump in the bottom compartment
    the fan was just there to hold the base up as i fitted the carbon, hole will be housing the pump
  3. Deblow
    Deblow Minimodder
    12 Dec 2013
    New switches fitted in working, 1st for the LED master on/off, 2nd and 3rd are for the UV lighting on/off
  4. Bladesingerz
    Bladesingerz Minimodder
    30 Nov 2011
    Very nice, looking forward to see the rest.
  5. Deblow
    Deblow Minimodder
    12 Dec 2013
    Thanks Bladesingerz,
    Ordered myself some black tights ( wife got a bit suspicious when they arrived lol)
    and some thin light wood to make a fan hole cover, this will go on the base of the desk near the PSU, and will eliminate the need for 120mm fan dust covers
    Here i have covered a old triple RAD fan extension, this will hold the 3 intake fans on the uper right side
  6. Deblow
    Deblow Minimodder
    12 Dec 2013
    old triple RAD fan cover cut down to a double for the lower air hole near PSU
    Wrapped ready for cutting
    The PSU and RAM
    Another fan cover wrapped and cut
  7. Deblow
    Deblow Minimodder
    12 Dec 2013
    Took some doing, but Finally worked out a way to keep the matrix LED's
    14/04/2014 - Just noticed i forgot to add the fan photos, so here they are
    CM Jet Flows - plane black no LED's
    Nice to have 2 speed controllers included with the fan, 1200rpm & 1600rpm
    forgive the sawdust didn't look that bad without the camera flash lol
    removable rubber ends!, if i had not already cut the wood i would have removed the four fan ends and cut circles not squares as the fans are about the same thickness as the wood and would have looked great.
  8. Deblow
    Deblow Minimodder
    12 Dec 2013
    RADs and pump in place along with the new pump carbon wrap cover (RES base)
    Needed to extend most the fan wires, forgot to take a pic
    The converted triple RAD fan holder fitted to replace the wood that was there on the test build
    redone the sides with new wrap, the triple RAD shown here was not in the test build,
  9. Deblow
    Deblow Minimodder
    12 Dec 2013
    made some blocks to raise the RES a inch higher, i might get a clear pump top in the future and light it????
    The tubing covering the GPU bridge can be removed, and atm its no longer on, cant decide if i like it on or of lol
  10. Deblow
    Deblow Minimodder
    12 Dec 2013
    New wrap added to the front, new switches and new fan controller
    also partially covered the blu-ray drive
    under the blu-ray is my drink holder (converted DVD drive)
    the bottom bay holds my main OS SSD drive
  11. Asouter
    Asouter --------
    18 Jan 2012
    Congrats on the Nomination ... build is coming along nicely
  12. Deblow
    Deblow Minimodder
    12 Dec 2013
    Ah, I've just seen the Nomination :D
    That's great, but will it matter that the projects not completed yet?
  13. Deblow
    Deblow Minimodder
    12 Dec 2013
    You can just about see the LEDs for the matrix cards on the sides near the volts - + buttons
    they can be moved around a bit but i think they look best on the sides
  14. Deblow
    Deblow Minimodder
    12 Dec 2013
  15. Deblow
    Deblow Minimodder
    12 Dec 2013
  16. Deblow
    Deblow Minimodder
    12 Dec 2013
    Most lights fully working now, water flowing nice, temps looking good
    Getting close to complete :D
  17. Deblow
    Deblow Minimodder
    12 Dec 2013
    that's all the pix for this weekend,
    more to follow later next week
  18. Asouter
    Asouter --------
    18 Jan 2012
    No it doesn't matter if it's complete yet, motm is about open projects that still have progress happening. it doesn't matter what stage your build is at :)
  19. Deblow
    Deblow Minimodder
    12 Dec 2013
    Thanks Asouter, i understand now iv had a good look at the other entries :D
    anyway, iv been doing some quick temp tests before i finish of the build,
    here's all my temp info for now -
    CPU @4.6
    GPU's Core @ 1260MHz, Mem @ 1800MHz
    Idle temps = (This test was done after all the 3D marks and gaming)
    CPU = 34c
    GPU1 = 29c
    GPU2 = 30c
    Water Temp before RADs = 26.1
    Room Temp = 22.6
    FANs at lowest settings
    3D Mark (default settings) did 4 tests back to back and until the temps was at the max
    CPU = 58c
    GPU1 = 44c
    GPU2 = 45c
    Water Temp before RADs = 33.3
    Room Temp = 22.1
    Heaven Bench did about 3 full tests at max settings back to back and until the temps was at the max
    CPU = 55c
    GPU1 = 39c
    GPU2 = 40c
    Water Temp before RADs = 29.5
    Room Temp = 21.6
    1 hr playtime on Grid 2 (maxed out)
    CPU = 54c
    GPU1 = 42c
    GPU2 = 43c
    Water Temp before RADs = 33.1
    Room Temp = 22.3
    All this was done with the fans on the lowest settings, as when im gaming without a headset i don't like the noise
    I will do more testing when the desk is done, but for now im more than a bit happy with the GPU temps
    i was hitting 85c and even up in the 90s when i was on air with the fans on 100% and that was only running at 1100MHz on the cores
    The OC on the cards and CPU is stable and i haven't messed with it much during this build, i could probably hit 4.8 on the CPU and possibly 1300 on the GPUs if im lucky
    3D mark score was 12751
  20. Darkened
    Darkened What's a Dremel?
    28 Feb 2004
    You've made really nice progress with the desk and it's looking good.
    If you've checked my OM thread, you'll know that I really do mean that you work fast :hehe:
    Also laughed at the image of you arguing with your wife on getting new dust filters and how it gives you a good reason to linger in the lingerie section :lol:
    Darkened
