Other MegaRAID 9361-8i Raid card advice
Discussion in 'Tech Support' started by Buzzons, 9 Apr 2021.
  1. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    Hi all,
    In my current file server I've got an HP P410 running a RAID6 of 6x4TB disks - this all works fine on my ASRock H170A-X1 motherboard.
    However, I wanted something a little bit faster when I migrate to a new set of disks so bought an LSI MegaRaid 9361-8i.
    However, nothing I do can make it appear in Windows under device manager - nor does it show up in a linux live CD (lspci shows no raid card) - nor can I make it load the pre-boot optionROM to manually create the array.
    To get the HP P410 to show up I had to use the attached settings in the BIOS - but I've tried swapping them over / setting CSM disabled / setting fastboot on/off - and nothing will make the optionROM load, nor it turn up in an OS.
    Any ideas? (or is the raid card probably broken? :( )
  2. creative
    creative 500rwhp
    23 May 2014
    I would download the firmware and flash tools from broadcom and see if its detected that way.
  3. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    So turns out card was 100% dead - I got another one and it just worked. Ah well.
