Memor Timings - Noticable differences?
Discussion in 'Hardware' started by BadHead, 20 Feb 2007.
  1. BadHead
    BadHead Minimodder
    16 Feb 2004
    Hi,
    Would there any real , noticable difference between memory running at 6-6-6-18 and 5-5-5-15 or 4-4-4-12? How about £50 worth of difference?
    Ta.
  2. trig
    trig god's little mistake
    10 Aug 2006
    seems to me, that the tighter the timings, the more room you have to overclock (and loosen timings if needed)...so although you wont maybe notice it in the normal day to day...it would be beneficial based on what you intend on doing on the overclock front
  3. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    The general answer is get the fastest you can afford. Most DDR2 does not have timings less that 5-5-5-15 I think (had a quick look on ocuk) and that is for crucial and corsair's budget range. As trig said, not a massive difference until you OC.
  4. trig
    10 Aug 2006
    hows my new pc coming?
