Memory :: 4x1Gb or 2x2Gb ??
Discussion in 'Hardware' started by Guest-23315, 29 Apr 2007.
  1. Guest-23315
    Guest-23315 Guest
    Just a quick question, for gerneral gaming and work performance, will 4x1Gb or 2x2Gb be better?
    Also, i'm after a little overclocking, basically getting a Q6600 over 3.00Ghz.
    I've so far looked at..::
    4Gb OCZ PC2-5400 C5
    Or, 2x 2x1Gb Crucial Ballistix 5400 C3
    Thanks guys.
  2. Bluephoenix
    Bluephoenix Spoon? What spoon?
    3 Dec 2006
    4x 1gb is better from my experience, and if you want some massive OC, nothing beats Flex or Dominator. (especially when you start upping voltages and get more heat)
  3. Tim S
    Tim S OG
    8 Nov 2001
    the current 4GB dual-channel kits are pretty high latency and are unlikely to be great overclockers, so I'd go for 4x1GB at this moment in time. :)
  4. Guest-23315
    Guest-23315 Guest
    Ok, thanks. Thats what I wanted to hear. Seeing as I can get 2Gb's now, and then upgrade to 4Gb later on!
  5. Zyphron
    Zyphron New Member
    26 Apr 2007
    good to know i was wondering the same thing, because people always told me u wanted 2x1Gb over 4x512.
  6. Bluephoenix
    3 Dec 2006
    it's all in the latencies, in some instances 4x 512 CAN be better than 2x 1gb; but with the lower latency 1gb sticks available now its usually not the case.
  7. Pookeyhead
    30 Jan 2004
    That's because 512 modules can be bought with very low latencies, sometimes less than CAS2, so you're not gaining anything by using 4x 256 modules... and just using up slots for nothing.
    However, larger modules are usually higher latency, and 2Gb modules are quite high compared to 1Gb, so in that instance it often makes sense to go the 4x 1Gb route.
  8. Fozzy
    Fozzy New Member
    25 Jan 2005
    Yes but if you ever decide you want 8gbs......I think you'll get the same performance with both but 4x1 takes up more slots. That being said I don't think you'll need more than 4gb's for at least a few years. 2gb's is prime right about now. But with vista using 60% of my ram right now (1gb) idleing.....i'd say 4 is going to be what you want
  9. DougEdey
    5 Jul 2005
    This. Is. Good. RAM is there to be used!
  10. Guest-23315
    Guest-23315 Guest
    I'm guessing that when upgrading from 1Gb of generic to 4Gb of overclockers RAM I should see a very nice speed upgrade?
  11. hughwi
    hughwi Well-Known Member
    23 Dec 2003
    I was also wondering this, i understand the latency problem, but does the 680 or the 650 chipset have any problems with 4x1gb? i remember that using all 4 slots on AMD chips in the past means you usually have to revert to t2 rather than t1. im guessing this was due to the onboard memory controller, and that for a C2D chip, this is irrelevant?
  12. Highland3r
    Highland3r New Member
    25 Jul 2003
    Speed wise probably not. The extra ram will give an overall better experience however.
