Memory Memory for my new I7 Build
Discussion in 'Hardware' started by slaw, 9 May 2010.
  1. slaw
    slaw At Argos buying "gold"
    13 Feb 2003
    Hi Guys,
    I have decided to build myself a new machine for my birthday (in 2 weeks in case anyone wants to send me something nice!!)
    I have decided to get a 920 (as they are so cheap at the moment) and lovely new Gigabyte ga-x58a-ud3r after reading the review on Bit tech.
    The problem is that I am a bit confused (amongst other things) about which memory to get.
    now what are you thoughts of any of the following 1600mhz kits?
    Patriot Viper Extreme Performance 6GB
    OCZ gold low voltage
    OCZ gold XTC
    Kingston 6GB HyperX XMP CL8
    or maybe the some 6GB ULTRA 2000MHz
    Does anyone use Geil? I have seen some good reviews yet hardly any one seems to use them. Is there something that they know that I don’t?
    I also have a couple of quick questions. I like my photography and in the future, I may increase my ram to 12GB. Would this cause a problem with overclocking?
    Last question, does increasing the memory voltage above 1.65 volts damage the CPU even if its well (water) cooled?
    Thanks for the help guys!
  2. bulldogjeff
    2 Mar 2010
    I would be tempted to go for the low voltage stuff. 2 reasons, less heat and power savings. I don't know what it overclocks like but i would imaging quite well because of the lower voltages
  3. slaw
    13 Feb 2003
    Hey
    any advise would be appercaited
    thanks
  4. adam_bagpuss
    24 Apr 2009
    get the OCZ low voltage ones cause there the cheapest.
    all kits you have listed are identical except the geil ones which are worse cause they have higher timings.
    the low voltage OCZ ones arent low voltage though just standard 1.65V like all the other kits.
    if your thinking of going to 12Gb of RAM then it may have a slight impact on overclocking because your populating all 6 dimms. you may find your overclock of say 3.8Ghz will drop to around 3.4-3.8Ghz but cant say for sure.
    i wouldnt overclock your RAM as it doesnt provide any real world benefit so you shouldnt need to raise the voltage above 1.65V.
    overclocking your Memory will also put extra strain on your CPU since thats where the memory controller is and will output extr aheat and would proberly result in a lower CPU overclock.
