MenloR's Mod v2.0
Discussion in 'Project Logs' started by MenloR, 31 Dec 2004.
  1. MenloR
    MenloR What's a Dremel?
    31 Dec 2004
    it's all (don't know the word, but here is a picture; http://members.lycos.nl/theegg/blowhole/117.gif ) and a bit of dremel and about 5 minutes of scrubbing.
    And the scratches in front bezel are visible but it is very smooth so i dunno what to do.
  2. hac
    hac What's a Dremel?
    16 Aug 2004
    you made those cuts w a jig?woah im impressed! kep up the good work! :rock:
    whats the problem w the front bezel again?
  3. MenloR
    31 Dec 2004
    Update
    I had some time and did the paintjobs for front and top. and i mounted my system in it.
    so here are some pictures.
    Here i put some bondo between the blue and white so it matches
    The cat of the neighbours was interrested.
    Here it is painted
    Here is my room with the case
    you can see my old case there
    And i just had to show my hard disks :p
    System in case
    Old case unmounted
    Some random pictures at night
    not much pictures, but i have to keep you updated :p
    some baybus info
    First switch: 2 front 120mm papst
    second switch : 2 top fans in top
    third switch: 2 front 80mm fans
    4th switch : 2 ccfl's
    5 & 6 not assigned yet
    need more info or pictures just ask, or higher resolution of any picture you can ask
  4. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    Hey MenLor, a great effort so far :)
    Your Front blow holes are comming along nicely, you havent stated alot on how your going about them.
    But from the piccys you really need to think about a few things.
    * Bondo! is made to work on metal, it dosnt really adhear well to plastics and certainly not smooth plastics.
    *I always make a point to ruffen (scratch scuff) up any plastic surfaces thats that bondo is being applied to.
    *Always try to work your bondo from edge to edge of the job, your not actually filling any holes here ! so anywhere that you rub back to plastic will appear as a "low" or a pool once paint is applied.
    Your picture # 9 shows this, you need to cover the orange that you still see
    another smooth thin layer of bondo applied with force. Then rubbed back again.
    * You really need to reinforce the back of the tubes! epoxy glue is best and lots of it!!! one small bump fitting it back up when painted and your front will crack.
    Not the sort of scratches left from bondo rubbing.
    to fill these you will need Spray putty primer or even spot putty.
    I think your doing an awsome job so far and from what i can see it a job worth doing well and pro like.
    This isn't a dig at your work but just a freindly few comments to help you along.
  5. MenloR
    31 Dec 2004
    i didn't do much today but here are some update pictures.
  6. MenloR
    31 Dec 2004
    i've worked some more
    and almost done
    this is painted and on case
    case and room
    what do you think uh?
  7. Acid Burn
    Acid Burn ..look but don't touch..
    14 Mar 2004
    the holes are really well done! and nice clean cuts on the door! And i like the fan grills inside the holes :)
  8. MenloR
    31 Dec 2004
    thx :)
    now only the other side panel to mod, and finished i guess :)
  9. rowan57
    rowan57 What's a Dremel?
    14 Dec 2004
    Does anyone else think MenLor should send at least 2 of his hdd's to me? lol j/k, gorgeous mod btw.
    Rowan
  10. -SilentNight-
    -SilentNight- Hardcore pro gamer
    24 Jan 2004
    nice going dude :) is that prety loud?
  11. purepope
    purepope Banned
    17 Jan 2005
    nice job (i wish i had a dremel, or at least my mum was home :sigh: )
  12. MenloR
    31 Dec 2004
    idd it's loud
    but the 2 120 mm i only turn them on at lan party's :)
    and the 2 upper fans are always at full speed and the blue led fans are at half speed almost all the time.
    And i don't send any hdd to you :p , i need it next week at lan the 160 is empty :( it has to be full )
    and the dremel and stuff, i got everything from my dad, in his early years he worked with wood, making tables and chairs and stuff so he has alot of tools, if you want i take pictures of my workplace :D
  13. luvbug
    luvbug What's a Dremel?
    22 Sep 2003
    Nothing but red X's man :(
  14. MenloR
    31 Dec 2004
    i think it's down atm
  15. MenloR
    31 Dec 2004
    My website was removed because i didn't made a site on it :)
    i will move it when i'm at home
  16. MenloR
    31 Dec 2004
    k everything is moved
  17. Silenced`
    Silenced` What's a Dremel?
    28 Aug 2004
    nice modding MenloR !
    grtz,
    Thomaz
  18. Sheiken
    Sheiken Wat?
    9 Jan 2005
    Looks really good there m8 ;) cant wait to mod my centurion this weekend! ;)
  19. Sheiken
    Sheiken Wat?
    9 Jan 2005
    Id like to see it :)
  20. MenloR
    31 Dec 2004
    k i'll do it tonight
