SketchUp Mesh material
Discussion in 'Modding' started by motas, 22 Apr 2010.
  1. motas
    motas What's a Dremel?
    7 Dec 2009
    I was wondering if you could make a material with half transperant half not. ANyway if you know how to do this or very easily and quickly make mesh that would be great. Thanks.
  2. Puk
    Puk (A shrewd and knavish sprite)
    23 Mar 2002
    Window tint film on Perspex, like car tints? Let's light through omni-directionally, different grades allow different light throughput. First thing that comes to mind. There was a terrific mod on here about six years ago (showing my age) with a clear case and window tint, pure awesomeness.
  3. motas
    7 Dec 2009
    I was talking about a sketchup material. I need to do somefan grills and somemesh around curves so I don't need to spend hours drawing circles.
  4. Puk
    23 Mar 2002
    Sorry! lol bloody iPhone, sketchy connection and didn't see the sketchup tag beside the post. My appologies!
  5. motas
    7 Dec 2009
    Np took me a couple of goes to figure out what you were talking about.
  6. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Hmm I'm not sure you can dude, I only say that as the default "glass brick" google mat that would have used it is transparent even in the grout lines.
    You could try using some plugins to make your life a lot easier with all the holes?
  7. Cheapskate
    13 May 2007
    Can you import a texture with an alpha channel or clipping path into SU? It would work that way. (I doubt it's possible because SU isn't particularly for rendering...)
  8. motas
    7 Dec 2009
    What about a material for twilight?
  9. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
  10. Editor22
    3 Jan 2009
    SU can handle Alpha mapping :) just done some research and came up with this
    Clickey
    Also you can see here that the mapping works on one of the default fencing textures.
    Hope it helps :p
    Cheapskate likes this.
  11. motas
    7 Dec 2009
    So how can I make a material of mesh for sketchup or twilight?
  12. motas
    7 Dec 2009
    I just made the fencing smaller and black and it looks alright
  13. voigts
    voigts What's a Dremel?
    26 Apr 2006
    I do the same thing with the fencing. i tried drawing modders mesh, but Sketchup has a terrible time handling all of the polygons, and the mesh doesn't look right due to the black outlines of the shapes. I've found that taking the blue fencing material and changing it to black and resizing it is a lot simpler.
