Im thinking of Doing a Mesh Window, for Airflow, and the ability to paint a design onto it easily. What would be the best type of mesh? Larger or Smaller holes etc. And how would i mount it internally? Im thinking a real fine mesh, i've decided not to have a side fan, the Mesh should allow air in, and currently my temps are good, with no intake fans at all. Any UK links would be great.
http://www.kustompcs.co.uk/acatalog/Kustom_PCs_Shop_Trim___Edgings_64.html B&Q? Mount it with rivets, bolts, 3M double sided tape, epoxy resin, your choice.
For better airflow I'd go with large mesh, for easier painting I'd go with finer mesh you have to decide which one is more important or try to find a balance between the two
I Would like to spray something like the L4D Sillouheute Survivors onto it, maybe in Red or Green, so the Tighter Mesh does seem like the best option.
