My computer is seriously f**ked. From the minute I built it it's not been working properly at all. It BSOD's all the god-damn time. I've checked the event log, and these are the errors i've been getting. All Event ID's are 1003, category 102. Error code 1000008e, parameter1 c000001d, parameter2 f8d53524, parameter3 80541e18, parameter4 00000000. Error code 10000050, parameter1 bd877807, parameter2 00000000, parameter3 bd877807, parameter4 00000002. Error code 000000d1, parameter1 00000000, parameter2 00000002, parameter3 00000000, parameter4 f0e01d81. Error code 10000050, parameter1 ff87aaff, parameter2 00000000, parameter3 ff87aaff, parameter4 00000000. Error code 0000000a, parameter1 0000000c, parameter2 00000002, parameter3 00000000, parameter4 804d6aa3. Error code 10000050, parameter1 bd877807, parameter2 00000000, parameter3 bd877807, parameter4 00000002. Error code 10000050, parameter1 8c877807, parameter2 00000000, parameter3 8c877807, parameter4 00000000. Error code 000000d1, parameter1 00000062, parameter2 00000002, parameter3 00000000, parameter4 f8ef362b. Error code 10000050, parameter1 bd877807, parameter2 00000000, parameter3 bd877807, parameter4 00000002. Error code 00000076, parameter1 00000000, parameter2 81346da8, parameter3 0000004b, parameter4 00000000. Error code 000000d1, parameter1 00000062, parameter2 00000002, parameter3 00000000, parameter4 f8f1062b. Error code 10000050, parameter1 cc880000, parameter2 00000000, parameter3 cc87ffff, parameter4 00000000. Error code 1000008e, parameter1 c0000005, parameter2 804f810b, parameter3 fa389e5c, parameter4 00000000. Any idea about fixes for each? PC: Soyo K7V Dragon Plus AMD XP1900+ Palomino 256MB Crucial PC2100 DDR (Tested, both chips OK!) 550W QTEC PSU / 300W Generic ATI AIW8500DV (Previously GF2 Ti Deluxe) On board sound Generic 10/100 NIC (Previously netgear) Western Digital WD800JB 80GB, 7200RPM HDD Pioneer Slot loading DVD Sony CRX145E-RP CDRW HELP! Before I smash this thing to small pieces!
A litle Google later and I found some threads blaming the video card/drivers for the errors; especially the GeForce 2 MX 200. Try a different driver or different video card for a bit and see if the problems don't go away.
I've done that. One thing though. I downed the FSB to 100MHz and the PC seemed to lose all stability problems. It's weird. What could be wrong?
Aggreeing with RTT... RAM is the source of a *lot* of instability problems. Run memtest and I'll bet you'll get some errors.
BINGO! My friend and RTT were right - the chipset was overheating and couldn't cope with 133MHz FSB. I took off the HS, cleared the dust, unclogged the fan a little and put on some thermal goop and the system appears to be relatively stable
