Cooling metal cool sleves?
Discussion in 'Hardware' started by THEkorean, 4 Oct 2006.
  1. THEkorean
    THEkorean 42
    10 Jun 2005
    i know they are not called coolseves, but i have seen these metal coils (similar to coolsleves, they kinda look like springs) around that people put on piping and wiring so that they can bend wihtout kinking? does anyone know what they are called?
  2. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
  3. THEkorean
    THEkorean 42
    10 Jun 2005
    yea, something along those lines, the ones i saw were coiled realy close at the source and the distance between the coils grew as the lenght of the anti kink spring (?) grew larger, anyone know what im talking about?
  4. duc
    duc What's a Dremel?
    9 Jan 2006
    Something like this?
    Link: Over-Clock UK
  5. hydro_electric_655
    13 Jul 2006
    [​IMG] like that but I would recommend the normal stuff just cuase you can get it easily and cheaply. These are used on some garden hoses to prevent kinking
  6. THEkorean
    THEkorean 42
    10 Jun 2005
    thats the stuff! any idea where i can get some? mabe at my local Home Depot in the plumbng section?
  7. Boswell
    Boswell Minimodder
    23 May 2005
    Sure![as in agreeing with you...] or BnQ.
  8. Guest-23315
    Guest-23315 Guest
    slight off-topic :: is there realy any point getting cool-sleves or coils or what ever, do they actually help to prevent kinking ???
  9. Firehed
    15 Feb 2004
    Varies by how you're configured, but I've found they help ranging anywhere from slight improvement to mission-critical.
  10. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    mission-critical indeed..
    I would not have been able to make the needed-bend without them..
    They also look good while going-so... :hehe:
  11. hydro_electric_655
    13 Jul 2006
    What they do is resist (strongley) the soft tubing from creaseing by keeping the tubing round. What they do is hold a circlular form very well so when fitted properly keep the tubing form going out of round. Which is creasing.
