Scratch Build – In Progress Metaversa 02: Ada
Discussion in 'Project Logs' started by Nexxo, 21 Jan 2014.
  1. Journeyer
    Journeyer Minimodder
    31 Aug 2006
    Interesting ... but have you seen that website? Took me right back to the mid-nineties. Still, it would be a lot easier (not to mention cheaper) to have it shipped across from the UK. Thanks again.
  2. Nexxo
    23 Oct 2001
    I simply took nickel reservoir to a local nickel plating company (Birmingham is at heart an industrial town and also has a big jewelry quarter). Stripping nickel from brass is simply a reverse of the nickel plating process --just swap the polarity. They did it for £10,-- IIRC.
  3. scopEDog
    scopEDog Minimodder
    5 Mar 2002
    Nexxo...if I would have known...I would of followed this from the beginning
    I'll grab a beer and watch the awesomeness :rock:
  4. Nexxo
    23 Oct 2001
    ScopEDog, dude! Good to see you here again! :clap: How have you been? :)
  5. scopEDog
    scopEDog Minimodder
    5 Mar 2002
    Not bad, can't complain :D I won't crowd up your thread, I'll catch you on PM
    Btw I'm digging the brass! Looking forward to updates
  6. Nexxo
    23 Oct 2001
    Small update: this week I took delivery of some True Brass Bitspower connections, notably the C47 Enhanced compression fittings for 12mm OD rigid tubing. I was pleased to find that they are a good match to the brass pieces that I have already made. I was also pleased to find that the 12mm OD, 10mm ID brass tube is a perfect fit. Of course with the lathe it was easy to cut a highly accurate piece with straight edges, and to smooth them for easy insertion without damaging the rubber O-rings.
    [​IMG] [​IMG]
    The first part of the loop: reservoir to pump is complete!
    [​IMG] [​IMG]
    More to follow soon... the tricky bit will be the short bend of tube from the radiator to the reservoir...
  7. Guest-23315
    Guest-23315 Guest
    ermahgerd brreeeessss
  8. Waynio
    Waynio Relaxing
    20 Aug 2009
    And it looks veeeery veeeery niiiice. :lol:
  9. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Damn, that looks so good!
  10. Cheapskate
    13 May 2007
    Awesome.:D
    ...Somewhere, someone is trying to figure out how you smoke with it.:( I blame that 90 sticking out of the pump.
  11. Nexxo
    23 Oct 2001
    Well, I have thought that I could make some awesome vapers (or bongs... :worried:) but I don't smoke. I am thinking of making my own espresso machine though. There are some logs on the web of people doing stuff like that and I imagine it isn't hard. Just a thermostatically controlled boiler and a spring-loaded mechanical valve with a group head, basically. :D
  12. GCOFIELDD
    GCOFIELDD Minimodder
    10 Oct 2010
    I have been away for a long time and when I come back I see this...I may have just crapped my pants a little.
  13. Cheapskate
    13 May 2007
    You ate at a Denny's yesterday too?
  14. Teelzebub
    27 Nov 2009
    I'm not sure that was the desired effect of Nexxo's hard work :worried:
  15. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    This is beautiful Nexxo!!
  16. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    It's just so damn sexy!!
  17. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    Yup,engineers porn which,as we know,is the best kind.
  18. Nexxo
    23 Oct 2001
    Thanks guys. :blush:
    By the way, stuff is happening in the background, albeit unexciting. I've got the D5 pump (PWM version), and also the EKWB Monarch X2 RAM block with the 'clean' plexi top (no circles) to match the mobo block. Also got the mill:
    But it still needs setting up. Once that is in place I can crack on.
  19. Teelzebub
    27 Nov 2009
    Nice mill mate what size bed is that? Next thing will be a power feed lol I'm still waiting for my replacement one once you get used to them you can't not have
  20. Nexxo
    23 Oct 2001
    The bed is 400x145mm (it's upgraded; usually it's 390x92mm). It is not the biggest mill, but at least it won't sink through the loft floor (hopefully... :worried: ). SIEG does a power feed but it's not locally available. I can always make my own. I think I've caught your modding tools modding bug. --I already have the gas spring upgrade on order. :p
