Scratch Build – In Progress Metaversa 02: Ada
Discussion in 'Project Logs' started by Nexxo, 21 Jan 2014.
  1. Nexxo
    23 Oct 2001
    Doing that. :D Works great.
    The piercing saw looks flimsy, but correctly tensioned these jewellers' blades cut through brass as if it was butter. It's really amazing. It takes some skill to learn not to break the blade, of course.
  2. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    I need me one of them there piercing saws.
  3. skyrip
    skyrip What's a Dremel?
    22 Jun 2013
    you should probably stay away from carbide mills with your manual machine. they are only interesting if you have a high speed spindle (or very high stickout) (6000rpm or more)
    also if you do not feed carbide mills enough they will wear faster(rubbing -> heat -> dull cutting edge) than a hss tool bit so for a manual machine with low rpm its best to go with hss tools. no coatings for alu is correct, everything except for polished surfaces sticks to alu and even that sometimes sticks to alu :p
    If you havent seen this site you should probably read it for some good background info: http://www.cnccookbook.com -> cookbooks
  4. Teelzebub
    27 Nov 2009
    Yeah I'm forgetting that Nexxo is talking about Mills whereas I've got the CNC on my mind atm I don't use Carbide on the mill only on the CNC which of course is running much faster than the Mill.
  5. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    Why do I want a mill and a CNC so bad now ? Glad I do not have anywhere to put them xD, that solves the issue and saves the pinky :lol:
  6. David
    7 Apr 2009
    Damn, that's pretty.
  7. Nexxo
    23 Oct 2001
    It felt a bit heavy in proportion to the other parts, so I took it back to the mill and metal files and tweaked it:
    [​IMG] [​IMG]
  8. Christof_II
    Christof_II SNAAAAAAAKE!!!
    15 Jul 2007
    I think that fits better with the aesthetic, good decision
  9. Guest-23315
    Guest-23315 Guest
    Looks better after its lipo :thumb:
  10. GuilleAcoustic
    26 Nov 2010
    I really dig the new design. Great job and wise decision.
  11. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    +4!! New design fits so much better.
  12. Cheapskate
    13 May 2007
    Dog bone brackets fit the style better too. :thumb: Sweet!
  13. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    Yup, a much more 'streamlined' solution,it would look the tits with some pocket work in them too......
  14. Cheapskate
    13 May 2007
    -Done with a ball end mill. :thumb:
  15. Nexxo
    23 Oct 2001
    Thought about it (I have ball end mills, which I am currently deploying on another project running in parallel to this one... more on that later), but I'm not sure whether that would be overkill. Where would the pockets go?
    Teelzebub likes this.
  16. barry99705
    barry99705 sudo rm -Rf /
    20 Apr 2008
    Couple little guys on either side of the screw.
  17. Cheapskate
    13 May 2007
    Maybe digging as deep into the tube holding bulges as you can and sanded insanely smooth.
  18. Nexxo
    23 Oct 2001
    I'd need a rotary table for that, really. Also if I add too much detail it risks looking a bit overdone. There has to be some functionality to it.
  19. KayinBlack
    2 Jul 2004
    You still need lead and colophony? Just now getting my feet under me after the stroke (and I had plenty of warning signs before it, I realize) and getting geared up for a project of my own and I realized I hadn't shipped you anything. No excuse other than busy with life stuff. If you still need it I'll get it in a box to you ASAP. Just shoot me an address.
  20. Nexxo
    23 Oct 2001
    No worries. I'd hold off on that for a while. I'm not at that stage yet, and I suspect that I can bend the pipe without, using the correct tools.
