Scratch Build – In Progress Metaversa 02: Ada
Discussion in 'Project Logs' started by Nexxo, 21 Jan 2014.
  1. Cheapskate
    13 May 2007
    Agreed. I still have my huge tub of Lego.
  2. Andreas | Brodholm
    Andreas | Brodholm Minimodder
    12 Jan 2013
    Yeah, it is really nice to have acces to one :)
    Okay! Just a heads up, 6082 is considered quite poor when it comes to decorative anodizing.
    "Decorative Anodizing can be a challenge due to crystal growth in the material."
    http://www.alumeco.dk/Admin/Public/...es/Filer/Alumeco/datasheet/Alumeco_EN6082.pdf
    More good info on the subject for those interested: http://www.alumeco.com/Knowledge-and-Technique/Useful-Info--and-Tips/Alloy-Choice.aspx
  3. Nexxo
    23 Oct 2001
    Thanks for the heads up. I was thinking of glass bead blasting as it creates a lovely satin finish, but old fashioned brushing works well too.
  4. Andreas | Brodholm
    12 Jan 2013
    Yes, that looks very nice! Just did not want you to send all that work to anodizing and then having it be ruined :(
  5. Nexxo
    23 Oct 2001
    I'd be like:
  6. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Thought about engine turning?
  7. Nexxo
    23 Oct 2001
    I have been experimenting with that actually. It's a lot of work... can't see myself doing large surfaces with it.
  8. phinix
    phinix RIP Waynio...
    28 Apr 2006
    I love the precision and finish... awesome job, man.
  9. Vault-Tec
    30 Aug 2015
    I love that switch assembly.
  10. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    oh, a tasty progress update. :thumb:
  11. Nexxo
    23 Oct 2001
    The switch gear is finally complete and installed.
    When the London Science Museum built Babbage's Difference Engine no. 2 in 1991, there was a tortuous process of making sure that all the thousands of parts and the huge metal frame housing the mechanism was in exact alignment. If the frame was even slightly warped, or one of the many, many cogs and levers was slightly out of position, the whole mechanism would jam. The first number of trials would often end with an abrupt crunch and a chilling >plink!< as a small part snapped and flew across the room like shrapnel, or worse, ricocheted around the mechanism to get stuck and cause a jam somewhere else. The engineering team then spent several hours trying to find the piece and also the broken part from whence it came, and then faced another few hours disassembling the mechanism, replacing the broken part and assembling it again to try again (oft with the same result all over again).
    I felt a bit like that engineering team, as what had been meticulously made to the tenth of the millimetre still was slightly out here and there. Luckily very little adjustment was required --almost nothing, really-- but the difficulty was finding out where the snag was. But in the end, it all came together --and my multimeter tells me the switches close as required. The whole thing has a fairly satisfying lever action.
    Close-up:
    Full frontal:
    The rectangular open space is where the four nixie tubes will reside.
  12. mal
    mal What's a Dremel?
    20 Nov 2012
    Are you sure you are building a PC.
    Looks more like a city electrical power station only much cooler. :thumb:
    mal
  13. Nexxo
    23 Oct 2001
    Er... :worried: Let me check my plans... I may have gone off track a bit...
  14. Cheapskate
    13 May 2007
    Never store your computer and death-ray plans in the same folder. :nono:
  15. Nexxo
    23 Oct 2001
    Ah. That explains a few things... :duh:
  16. sk8ter646
    sk8ter646 Minimodder
    4 Oct 2005
    This is just a pure piece of engineering art I love it!!!
  17. GLA-58
    GLA-58 What's a Dremel?
    1 Sep 2011
    Is there an update yet to this beautifull build ?!?! :)
  18. Nexxo
    23 Oct 2001
    There will be... work has been a bit of a distraction. Meanwhile I have been using my tools to make more tools... such as this mill stop:
    This will allow me to "mark" the position of a work piece in the vice, so that when I take it out I can put it back in the exact same position. Also useful for performing the same operation on a number of identical pieces.
    I have also been redesigning the circuit board for the nixies a bit. Using the Ogi Lumen kit is just a bit too awkward. The circuit is built around four Russian K511ID1 driver ICs and two 74HC595 shift register ICs, and takes up a lot of space...
    (I was going to redesign the top boards for the IN-14/19 nixes rather than the IN-12A nixies that come as standard.)
    The problem is that this circuit does not do decimal points (unlike the IN-14, which has two, the IN-12A has none) so I'd have to reserve some ports on the Arduino to drive these separately via a transistor, and I then have to find somewhere to accommodate an Arduino and a nixie power supply... even if I use the Arduino Nano that would be a squeeze:
    However in my many travels on the web I came across the HV5530 high-voltage driver chip. This petite little item (9.8mm square in 44-pin PQFP package) has 32 outputs and can drive up to three nixies. Two of these can drive all three IN-14 digit nixies plus their decimals and the IN-19 symbol nixie with ports to spare and talk directly to the Arduino, no additional parts needed (although the spec sheet says that its logic gates operate on 12V, various electronics geeks on the internet say that in practice the 5V Arduino channels work just fine).
    So, two of these chips would allow me to squeeze the nixie circuit in a single PCB and bolt the Arduino Nano and a small nixie PSU underneath as a second PCB.
    Now all I have to do is design the circuit, write the code... I have some work to do.
  19. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    Who are you guy and whatchoo doin posting in this thread?
  20. Cheapskate
    13 May 2007
    I'm hoping you put together a full tutorial with circuit maps and code.
    ...The more paint I inhale, the less I feel like I can handle that stuff on my own.
    I like the workstop, but a block mounted on the mill do the same for the cheap.
