Scratch Build – In Progress METO aKa projekt scrapheap challenge - watercooled and topped
Discussion in 'Project Logs' started by p0Pe, 26 Nov 2007.
  1. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    that should be it spammed to page 2... sorry, but the 100 of image on the other page was annoing xD... now for the update:
    the finished milling result... will have to do some more about this... but you get the idea...
    (sorry for blurry pics...)
    and the other side... i might do something about the milling traces, sand it or something... might paint it on one side... still thinking.. any suggestions?
    it looks sooo cool under UV:D.. i have a m8 thats foto freak and hope to maybe give him the challenge to take a photoshoot of the thing when its done xD.. would be nice
    comments?
  2. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    sanded it down a bit:
    and how it looks under uv
  3. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    aaaaaaand.... christmas update!
    tapping time!
    done with mobo plate
    hdd & dvd plate fitted
    and feets:) which are gonna be led as previous mentioned.
    thats all for now and a while, marry christmas everybody!!!
    may you get the modding parts you desire:)
  4. Macros_the_Black
    Macros_the_Black Yup.. I'm a f-ing reptile
    7 Jul 2007
    From what I've read... don't remember where, but I think it was in a comment thread to some extensive fan test.. perhaps over at scilentpcreview.com... anyway, those Noctua fans don't handle back pressure well, and thus they are not well suited for pushing/sucking air through a radiator.. especially not with that restricting hole mesh on it. Another fan with less steep angle on the fan blades might give you more cooling at the same noise level. The Nexxus D12SL-12 fan for example, is very quiet and handles the back pressure better. I bet there are other fans that would work better as well.
  5. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    ive tryid to get those fans but they are not selled in my country:(
    i got the camera working!... sort of.. got my card reader working so... a little loose end from last:
    the feets:
    and i got my dremel at christmas!§
    niiice
    just kidding...
    dremel 300:
    and got the spare plates cut off the main parts, made the whole thing look twice as small xD:bunny:
    and them both... it still looks very non finished:p... but i hope itl soon change! just have some hardware i need :/
    i couldnt resist!.. a little teaser and need som help from you guys:D
    masking tape... gonna be removed soon tatadaaaa
    blurry pic sry for that xD
    NOW!... should it look like this:
    or this:
    i think im gonna go for the brushed look and i might paint it black... will have to try this on some scrap piece.
    also made my own home made round IDE cables because i was bored:D this is very easy to do and they work fine afterwords, just get a little knife and cut a tine whole between the wires and then just use force to seperate the rest from the rest of the big wire:D
    thats all i got for now:)... happy newyear and comments to everybody!
  6. rytmehunden
    rytmehunden I love glory and fame
    30 Dec 2007
    Looks fine / ser godt ud :D
    Im looking forward to seeing the mod in its final phase. Think its gonna look sweet!
    Keep up the good work :D
  7. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    thx alot:D yeah.. just hope that it gets to that phase soon xD
  8. Toxvaerd
    Toxvaerd What's a Dremel?
    29 Dec 2005
    Hey pOPe... very nice craftmanship. Looking forward to se how this looks when its done.
    Keep up the good work ;)
  9. gnidnu
    gnidnu Beware of the Tofu!
    9 May 2006
    Looks interesting, but: Would you please resize your pictures? They take almost 30 MB on the first page and more than 15 MB on the second page. That's way too much. Loading takes ages and scrolling is less smooth than usually.
  10. Cheapskate
    13 May 2007
    The pics are huge! I can tell you need to clean under your fingernails!:D
    Seriously, you will run out of bandwidth soon if you don't resize them.
  11. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    that should do the trick:).. just have to find the rest of the pics and reupload them:) they are on my lappy or some other place lol
    thx for the comments:)
  12. C-Sniper
    C-Sniper Stop Trolling this space Ądmins!
    17 Jun 2007
    Thats the same mobo i have in my linux server :D
    looks good. gonna watch this one.
  13. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    update about the raddy:D
    finally got some spare time to play with the computer again
    and cleaned my desktop:p
    at school i made this for fun and to see how the text would turn out, it was just a quick skecth but i like it
    look how thich this plate is:D 10mm xD took a lot of time to mill
    for the raddy mount this was what i made first
    i then decided to just make 2 plates that would hold each end
    no chance of the mobo suffering of air need:D
    from the rear
    again
    mounted with theese
    and this was a little idea i had, gonna think a bit more about that heh
    just playing with the design for the top, take a look:)
    scanning the drawing in and making it a texture
    making splines above the text
    correcting measures of splines
    extruding the splines to get the text
    applying text to a plate
    the finished result with a glass plate on the back:
    thats what i just got made:) im thinking of something in the middle under and above the text but didnt get that made today:) so now im going home:D
    thats all for now, im wating on reply on how to get the missing parts and hopefully ill soon make enough money to buy em if i cant get something sponsored:D
    have fun lads^^
  14. NZ_mod_man
    NZ_mod_man What's a Dremel?
    26 Aug 2007
    Nice! looking good! keep it up! :thumb:
  15. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    ive also made a drawing of the side holders... this should be done tomorrow i hope:)
  16. rytmehunden
    30 Dec 2007
    Yo pope.. If you need hosting you can use my webhotel..
    It´s with unlimited bandwidth, so gimme a pm if you want access.
    That sideholder looks advanced! Looking forward to see how it turns out :)
  17. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    ey thx man ill considder that:) right now im working on whats its gonna cost me to get the same on my website:p but its a nice offer takker så meget:D
    finally got the parts done!... my group mate came 2 hours late so suddenly we had alot to do:/.. but i managed to make a little of my own once in a while:)
    the results (no wip sorry... but guess you know the drill:p):
    and this is how they are to be placed:
    the wholes i countersunk
    so it would look like this
    you can really see the milling traces xD... looks kinda cool actually so i think ill keep it this way
    and the fun part! tapping:bunny: dont know why but i love this part
    there is only one little problem, you would notice that on the first picture there is a gab between the bar and the plexi... this is why:
    ... have to countersink this mofo:).. but then everything should fit like a glove:D
    and you may have noticed all the closeups:p... i "borrowed" my sisters cam and went mental... this was what came from that:
    that was what i had to offer
    comments are highly recommended or else the dog is gonna eat you! xD
  18. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    looks very nice.. keep up the good work..
    by the way, are you from denmark?
  19. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    yes i am:D
    have a look at this:D
    the hoses to the harddrive compartment
    and i put it all together after having cleaned and sanded the edges down on the alu pieces i made
    that thing is rock solid:O
    the large screws is gonna be replaced with some shorter ones:p... but i didnt have any other xD
    and this sucks... i kinda knew it but choose to forget about it:/ have to do some dremel work here... the bit thing has to be clear of the plexi
    and some perspective shots:)
    and got a hold of theese 4 cobber pieces:D:D:D gonna use them for something... havent decided what yet:p
    but there are many thing to do with such goddies:D
    cu later:) hope you like:D
  20. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    custom heatsinks?
