Scratch Build – In Progress METO aKa projekt scrapheap challenge - watercooled and topped
Discussion in 'Project Logs' started by p0Pe, 26 Nov 2007.
  1. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    the gfx opperation lol... this is the thing that before easisly rised to 86c :O
    so on with the gloves and you go doctor! actually had to use a vertical drill to get some of the screw out :O man was i nervous there xD
    looks like a whossy without the cooler xD... it was SOO light!
    dont know if you can see this but that is actually a fly xD... yeah it was quite dead i think/hope... dont know what they are thinking... also once saw one fly into one of my fans lol...
    ATI yeeeeee !!! we like!
    mhhh... looks gooooood
    the loop as i would have had it... thought is was a good idea atm:/
    it sucked bigtime.. and made an unbelieveble noise!
    sooo... out whent the pump station... gonna use this in another mod so it isnt wasted:D
    when i sad with it there i came to think of that this actually was what i had based the mod on from the start:/... a compact pumpstation lol... it was so be said the HEART of the system and look at it:D with the vains, and blood coulor lol... i was kinda scared that i might just had killed my mod :S
    "lol"
    oh oh:D and also found theese pictures:D the prize pack from thebestcasescenario modders challenge 4 xDDD soo much hardware... thx to tbcs crew that made that happen!
    how it ended :
    here we gooo!
    this is gonna be moved
    DAMN this is nice looking!!!
    the damn thing actually changed my temps on the gpu from 86 peak, to 50 peak load xDDD and that was with only 1/3 fans on the raddy startet lol
    also used the grafic card that i won in modders challenge and used this to my second screen. now i could actually use 4 monitors... hmm.. where do i find the other 2 xDDD
    the watercooling works perfectly! damn this shiz rocks:p the noise level is low and so is the temps xD love it... the loop just was a PITA to fill:/ but who cares xD... it works now heh...
    have a nice weekend:D
  2. NZ_mod_man
    NZ_mod_man What's a Dremel?
    26 Aug 2007
    WOW! Come together quite nicely. Those DangerDen blocks are nice looking blocks.
  3. Supra55
    Supra55 What's a Dremel?
    10 Oct 2006
    The blocks look amazing with the coolant, good job.
  4. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    And then it was time!
    The final parts has arrived! Better late than never xD
    We will start of with something basic to avoid this:
    The first filter I made was… erm… not that god. Glue was to visible but it was ugly.
    And it didn’t fit all that god
    So… back to the top!!!
    This is the “evolution” for the tops.
    The top 2 is the final I got. The right one had little lines in it to make it easier to bend, and it worked like a charm, so after that I went on to sanding
    A long process… first grid 280, 800, 1200 and then final 2000
    And came out with this
    The filter for the top came out nicely!
    And a little peek at the back! God no one will see this side:p beside.. erm.. all of you lol
    The engraving
    I made a comparison with the engraving before and after sanding, check it out!
    Before
    And after
    And the whole mombo fitted on!
    Still needs 3 small things. Drill the wholes for these
    And make this fan for the hdd rack fit better and get that into place
    And make a proper on, off switch.. the one you see in the pics above wont do!
    But that was that:D finally! After way to long time I declear the scrapheap challenge ALMOST complete. And damn it has taken its time…
    But here comes the eye candy! Enjoy
    Missed a little with the sanding
    And the back
    And the whole thing in its rightfull place!
    hope you like it! night shots will come soon!
    cu all!
  5. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    and now! lady´s and gentlemens, put on you googles! beacuse here comes the lightshow!!!!
    there isnt really much to say so ill just let the images speek for themself
    hope you like it:D i do xD
  6. Cheapskate
    13 May 2007
    I like it. It came out a lot smaller than I thought it would. UV pink and green is pretty daring.
  7. JAxen
    JAxen What's a Dremel?
    18 Nov 2005
    Very nice mate :thumb: !
    But I wonder why you has that fillport in yer loop.
  8. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    yeah... the fillport was a mistake. or... i didnt have a hose long enough to fit the lasts piece so i sadly had to put the fillport in:( if i can find some hoses or buy some ill change it:D
