Playstation 3 MGS4 Save System
Discussion in 'Gaming' started by dinjo_jo, 15 Dec 2009.
  1. dinjo_jo
    dinjo_jo What's a Dremel?
    11 Dec 2008
    The save system in game is so bad it does not saves frequently only when you go manually and save it , works.
  2. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    More incentive not to die!
    Although, I've never had an issue with its save system.
  3. acron^
    acron^ ePeen++;
    15 Oct 2001
    dinjo_jo, you just failed the Turing test.
  4. glaeken
    glaeken Freeeeeeeze! I'm a cawp!
    1 Jan 2005
    I never really had a problem with the save system either.
  5. mikeuk2004
    mikeuk2004 What you Looking at Fool!
    3 Sep 2004
    I dont recall having an issue with it.
    However there are plenty of bad games out there that dont even let you save until you get to a save point which you have to find!!
  6. reggie50
    reggie50 Minimodder
    24 Apr 2009
    I thought most of the save issues on consoles are caused by the console requirements themselves. i.e. limited space for save data etc meaning you can only save at certain points.
  7. dinjo_jo
    11 Dec 2008
    The saves does not have enough checkpoints i mean
  8. glaeken
    1 Jan 2005
    I think nowadays it's more of a mentality. Consoles have more than enough space to store many save game files.
