Scratch Build – In Progress microbuild 001
Discussion in 'Project Logs' started by darknessblade, 12 Sep 2016.
  1. darknessblade
    darknessblade New Member
    23 May 2014
    hello guys it has been a while.
    i am making a custom 3d printed case for 1 of the smallest motherboards ever featured on this site.
    that can run linux or windows native. (so no special made versions),
    some size information:
    motherboard:
    front:
    advantech pcm 9361
    back:
    (picture is not mine, took 2 from online) (will upload foto's i made later)
    the case will be fully 3d printed.
    support for 1 slimline sata dvd drive
    support for2x 2,5" HDD
    the pc will run on linux, since its not powerfull anymore to run on windows 10
    and due driver issues
    will upload screenshots of the designs later (including beta/test layouts)
    part list:
    advantech pcm 9361
    gigabyte TA7 psu (since its small formfactor)
    kingston 16GB CF card
    2GB ddr2 ram memory (taken from a old laptop)
    lots of 3d filament.
    40-60mm fan
    2.0mm usb connectors
    remapped the PSU cable, so it fits the board.
    (need to add connectors for 2X sata)
    due a hardware glitch i will have to use 3 powerswitches to boot the system.
    1= green psu cable
    2= boot jumpercable -> powerswitch location.
    feel free to give feedback regarding printing/working on this (eg: on wich resolution would be the best/other)
  2. darknessblade
    23 May 2014
    here are some models:
    beta:
    beta 2
    final 0.9
    final 1.0.0
    and yes the final model is smaller than the original beta- versions.
    "due corrupt lines in the model, i have to remake it, since the .STL will be corrupt otherwise, i am unable to print Final1.0.0 due this issue"
    i did this to save on space while printing.
    but still keeping the options to add extra hardware like dvd+HDD or 2HDD
  3. darknessblade
    23 May 2014
    reserved2
  4. darknessblade
    23 May 2014
    reserved3
  5. darknessblade
    23 May 2014
    reserved 4
  6. darknessblade
    23 May 2014
    reserved 5
  7. darknessblade
    23 May 2014
    the project is not death yet, i am currently busy, correcting the corrupt lines in the build. wich prevents me from 3d printing it correctly.
