News Microsoft adds heatsink to the 360
Discussion in 'Article Discussion' started by Tim S, 14 Jun 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    about time......
  3. thermalnightmare47
    thermalnightmare47 What's a Dremel?
    18 Sep 2006
    most definitely about time, well there is a downside though....no more smores off the back...lol
  4. SNIPERMikeUK
    SNIPERMikeUK What's a Dremel?
    21 Feb 2006
    This is a day to mark!!!
    I have recently bought a 360, after just 3 months the lense went on the optical drive, had a replacement. The system is unreliable but it's a gr8 console, if this heat pipe 'n' sink works then all good but I hope they do this to all consoles to come, coz I have a feelin' a replacement will be needed before my 12 months are up.
  5. Omnituens
    Omnituens What's a Dremel?
    5 Apr 2006
    anyone know if the extra heatsink has already been fitted to the Elite model?
  6. Spacecowboy92
    Spacecowboy92 Gettin' Lazy
    10 Apr 2006
    I guess it will defiantly be on the elite model. And yes about time Microsoft adressed this problem.
  7. devdevil85
    devdevil85 What's a Dremel?
    29 Nov 2006
    Yeah, my friend's 360 has been acting strange lately. I think it's got to do with the harddrive because it has been hickupping tremendously and it's also been saying (Clean Disk/Disk Error) when playing a demo off of the hard drive. I don't know if heat has been the cause to any of it, but I know that it could choke any day now and all of our Guitar Hero II saves will be gone (except for our Live stats), but still that's gonna suck.
  8. LVMike
    LVMike What's a Dremel?
    11 Aug 2004
    He needs to delete the demo and re download it. that solved the problem for me when i had that.
    I don't believe the elites that were released in May have the new heatsink I dont remember seeing it in the engadget photos when they took theirs apart. The only thing i remember was the epoxy around the chips.
  9. Veles
    Veles DUR HUR
    18 Nov 2005
    Isn't that lawsuit you linked to a complete pile of ******** since the house burnt down before the 360 had even been released? That might be a different one though.
  10. Mathmarauder
    Mathmarauder What's a Dremel?
    14 Jan 2007
    The elite does not have this new heatsink. The problem was the heat was melting the thermal compound causing the heatsinks to lift away from the gpu/cpu. On the elite they epoxy'd the heatsinks down around the edges so there is no way to lose contact.
  11. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    So if i own a "old" x360 and call ms. And ask for a heatsink upgrade. Will they do it?
  12. devdevil85
    29 Nov 2006
    Nope, cause M$ = greedy. If they weren't then they would've added it originally or so you'd think.....
  13. ./^\.Ace./^\.
    ./^\.Ace./^\. What's a Dremel?
    7 Jun 2007
    If you are really woried about cooling your X-Box 360 then there are liquid cooling options that you can look into :dremel: , or just replace the thermal past your self and you can even try and find the new heatsink on ebay or something like that :D
Tags: Add Tags
