News Microsoft confirms Marketplace 'kill-switch'
Discussion in 'Article Discussion' started by Tim S, 18 Sep 2009.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. mclean007
    mclean007 Officious Bystander
    22 May 2003
    Good. As long as they're upfront about it, this is a very sensible feature. If an app gets approved, but later the approval is revoked because the app (say) contains hidden malware, it is a smart precaution to remove all existing installs. That way, users don't need to manually remove it to protect their device.
    In an ideal world, of course, this wouldn't be an issue, because all apps would be properly screened before going live, but we all know there is no such thing as a perfect filter, and things will get through that will be later revoked.
    One point though, if a paid-for app is revoked retroactively, presumably the user gets a refund and MS has to try to recover any royalties paid to the developer?
  3. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    I fail to see what right they have to go on your phone and remove stuff. If they no longer think an app is safe, they should transmit a warning to you so you can delete it yourself.
  4. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    I agree with this, or maybe take it a step farther. Have the option to turn it on or off. Leave it on by default for the majority of users who wouldn't understand what something like malware is anyway.
  5. wyx087
    15 Aug 2007
    at least Apple lets you keep your apps......
  6. Jozo
    Jozo This is bit-tech
    14 Mar 2009
    For preventing malware? OK, but it seems it won't be used only for that. I hope you'll be able to disable the option in registry.
  7. xprodancer
    xprodancer life is like a box of chocolates
    24 Jul 2009
    on this subject, if they can delete apps from your fone what else can they do without you knowing????? if an app was removed from the marketplace you would not realy know it had been removed! they should realy think about this one and maybe send a sms to everyone that has that app and ask if they want it removed due to it not being on the marketplace anymore! not just remove it so when you go to use it its not there no more!! if you payed for it, then why cant you keep it if you wish???
  8. B3CK
    B3CK Minimodder
    14 Jun 2004
    I have never used a windows mobile, but I would say that if I buy an app, it's mine, and legal suits would follow if they deleted or even disabled it. If it is a leased or rented, who knows? And what if you get the same app from another location other than their marketplace, and they delete something they didn't have rights to?
Tags: Add Tags
