Windows Microsoft, Java....bah!
Discussion in 'Software' started by Shadowspawn, 25 Jun 2003.
  1. Shadowspawn
    Shadowspawn Another hated American.
    1 Jul 2002
    Ever since MS was forced to remove Java from their OS's, I've been having problems. I installed Sun's Java and I get java errors on alot of websites. Are you guys having this same problem? Is their a fix for it? I've searched Microsofts site for a fix, but they are less than helpful. All I can get is a few references to MS Virtual Machine, but no download link. What gives?
  2. ajack
    ajack rox
    17 Apr 2003
    I had that problem but downloaded Sun Java and everything was fine.
  3. OneSeventeen
    OneSeventeen Oooh Shiny!
    3 Apr 2002
    Try browsing this site and near the bottom there is a link to a MS Java installer file.
    My advice is just do an Edit>Find "IF SINGLE PLAYER GAMES WON'T LOAD" then in that section number 3 gives links for 2 different versions of the installer.
    I'm about to install it and see how things go, but it looks like someone was nice enough to save an old version for us :p
    EDIT:: I installed it and it has been working fine for me, although I find it curious that MSN's Gaming Zone sports software that won't run on new versions of Windows. Couldn't the games be tweaked to run under regular Java?
  4. yodasarmpit
    yodasarmpit Modder
    27 May 2002
  5. Shadowspawn
    1 Jul 2002
    Thanks, I will check out these links tonight when I get home.
