Microsoft Laser 6000
Discussion in 'Hardware' started by xrob, 6 Jan 2006.
  1. xrob
    xrob What's a Dremel?
    31 Dec 2005
  2. Fr4nk
    Fr4nk Tyrannosaurus Alan !
    12 Mar 2005
    1. go to: control panel > mouse > pointer options [tab] then pull the dial down. that should slow down the mouse. Also I'm used to playing games witht eh mouse extremely fast, it just means you have to move the mouse less.
  3. Krikkit
    21 Jan 2003
    That's really fudged up dude, it looks like it might be faulty to me, have you tried it on all sorts of different surfaces etc? Have you tried an older/newer driver version? Cleaned the lense?
  4. Mister_Tad
    27 Dec 2002
    I'm using the same mouse, its just like any other mouse but more sensitive, I'd be inclined to say your mouse is fubarred or you're on the wrong type of surface as well
  5. xrob
    31 Dec 2005
  6. hitman012
    hitman012 Minimodder
    6 May 2005
    Sounds like your mouse is screwed to me :\. Have you tried it in another computer? Also check for any gunk around the optical assembly.
  7. customh
    customh conflagration.
    22 Oct 2005
    Im with hitman... try in another comp, if it does the same.. well duh the mouse is screwed up.
  8. Eliminos
    Eliminos What's a Dremel?
    2 May 2005
    I'm guessing that because its a microsoft mouse it doesnt come with drivers. But if it did and you installed them, try removing them, and if it did and you didnt install it, try installing them.
    This is after for you try it in a different computer.
