News Microsoft patch borks scrolling on IE 6
Discussion in 'Article Discussion' started by GreatOldOne, 17 Nov 2003.
  1. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
    From the Inq:
    WE DIDN'T want to write this story until we'd verified it for ourselves.
    But old Microsoft appears to have borked the scrolling with its Q824145/K824145 "update", which is beginning to destroy a version of IE we've got here.
    We're experiencing somewhat of a double scrolling problem here on our machines.
    There's a bit more on this here. Does this prove that "Windows Update" is an oxymoron? ;)
  2. dagamore
    dagamore What's a Dremel?
    2 Nov 2002
    just one more reason not to use IE for anything.
    i would try opera as a fix for this :D
  3. quack
    quack Minimodder
    6 Mar 2002
    I was in the middle of installing that update when I stumbled across the Inq reporting that. GRRR!! I haven't actually rebooted yet, so I'm not sure if it's going to cause me much trouble. At least it's easy to remove :)
  4. Atomic
    Atomic Gerwaff
    6 May 2002
    I know what im gonna be getting calls about tomorrow... great. More work for me.
  5. Kermet
    Kermet [custom title]
    18 Feb 2003
    This is the first thing I read after the post windows update restart, no problems for me though...
  6. KinGvsKinG
    KinGvsKinG What's a Dremel?
    20 Apr 2003
    mozilla is the way to go.
  7. Kermet
    18 Feb 2003
    I use IE for normal use and Opera to use my uni's web proxy so I can access the intranet.
    I actually prefer the plain and simple IE to other browsers that seem to try and compete by adding a ton of useless **** I will never use. Plus with IE everything displays perfectly which occasionally doesn't happen with some other browsers...
  8. sadffffff
    sadffffff Minimodder
    20 Oct 2003
    i just updated this morning and have had no probs...
  9. sadffffff
    20 Oct 2003
    probably a glitch from having paegen browsers installed
    j/k
  10. stevehp
    stevehp What's a Dremel?
    6 Jul 2002
    It also seems to break the handy links in windows explorer(left pane) you click on em' and they don't do a darned thing I reinstalled IE which worked.
Tags: Add Tags
